Panel Lines and door mouldings
Posted by Anonymous on Tuesday, August 10, 2004 2:59 PM
I am sure this is a repeat question but in terms of technique my search didn't come with much. How does one cleanly black out the mouldings around a car door? And how does one do nice pinpoint panel lines? I just started the Tamiya Sogo Kiebi Porsche 911 and I am dreading this particular part of of the project. I've done mouldings in chrome foil to good effect before but this model simply has flat black lines and mouldings. Any thoughts? By the way I've never built a "display" kit before. Kind of weird to work on a model without an engine!
Posted by dubix88 on Tuesday, August 10, 2004 3:17 PM
HEY,
Ive heard of painting the panel lines black before the final color coat, and it shows up nice after the clear coats. Not sure though ive never tried it.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Tuesday, August 10, 2004 8:07 PM
for the panel lines you could just use a wash of black or darkened(sp?) version of whatever color you plan on painting the body. You could also you a Gundam Marker
Mouldings around a car door ,do you mean the window rubbers? If so this site has a tutorial on how to do that
http://www.geocities.com/jdmf_2003/tutorials.htm
Posted by dubix88 on Tuesday, August 10, 2004 8:19 PM
HEY,
Check out those tutorials, they are great. My compliments to whoever did them.
Randy
Posted by Anonymous on Wednesday, August 11, 2004 7:22 PM
I use BareMetal foil black chrome. It's the easiest way I've found.
Paul.
Posted by Anonymous on Wednesday, August 11, 2004 8:07 PM
use a wash. it is a thinned down acyylic paint. get a semi gloss acylic. mix it if 5 part water, 1 part paint, and 2 part liquid soap (Dawn, exc...) paint it in the panels and let it dry. then whipe over the panel. the wash will stay in the line, the other will whipe off. the soap inables it to lift of when dry. you may have to experiment a bit (more soap if not lifting up. exc..) hope this helps.
Posted by Anonymous on Friday, August 13, 2004 12:23 AM
As far as those Gundam Markers, where can I get some of those??
Posted by dubix88 on Friday, August 13, 2004 10:48 AM
HEY,
Ive also heard about using a very fine tip mechanical pencil to to the panel line.
Randy
Posted by Anonymous on Friday, August 13, 2004 2:07 PM
Michaels crafts stores has them or something similar. Don't know where you are, so I hope this helps.
