Academy Benetton
Academy Benetton
Posted by Anonymous on Wednesday, August 25, 2004 3:58 PM
Hi
I am thinking about buying the Academy Benetton F1. I was woundering if it is any good. Like how is the fit and the decals. And is it easy to build.
Thanks, David
    March 2004
Posted by SeaBee on Friday, August 27, 2004 5:43 AM
David, I had one which I converted to Panis' Ligier. I am going to be frank. It's easy enough to build. But it is nowhere close to Tamiya in the quality stakes. Fine if you want it as a curbside model, but esp engin detail leaves a bit to be desired.
Can't answer on the decals, as I used F1 Specialties' decals to do the Ligier convertion. I am presuming you want that model because of the driver. I'd advise you (IMHO) that if you want an early (pre-Ferrari) Schumi drive, rather go for Tamiyas B192.
Btw, if I remember correctly, there is quite a bit of tricky masking involved for the blue and white borders, which is not supplied in template-form.
As said, the Academy goes together easily and makes for quite a nice curbside build, but it lacks a bit of detail. Also check some wings and endplates for being a bit too thick for scale - easy enough to rectify, though. Depends what you want/expect from the model. I'm not saying you should not buy it, just what to expect.
It's a very nice model in that it's almost the only F1 of that era, where Tamiya suddenly stopped bringing out F1's regularly. And the colourscheme is quite nice, as well.
Posted by Anonymous on Friday, August 27, 2004 9:26 AM
Thanks alot for all the help! I have only just gotten in to Formula One cars. Only built Tamiya's Renault Turbo. Thanks for the help again.
David
    March 2004
Posted by SeaBee on Monday, August 30, 2004 7:23 AM
David, it depends on what you've got available and how experienced a modeler you are. The only "difficult" part in this kit, if you want it to be curbside, is the masking between the colours. If I remember correctly, a lot is given to you in decals, but I'm not sure. If you want to find your feet at F1 modeling, this will do fine. I just feel a few of the Tamiya kits go together a bit better, some even have completed rear wing assemblies, which is pretty easy to get wrong.
I have also found some of their newer kits, despite having more detail, being easier to build. Joins better defined, etc. I still haven't started on any of the two Williamses in my cupboard, so I can't comment on that. But the F2000 and MP4/13 went together like a dream.
Happy hunting! Keep us up to date!
