Removing paint
Removing paint
Posted by Anonymous on Saturday, December 18, 2004 11:42 AM
I know I saw somewhere on how to remove paint from plastic parts but I can't find it. I need to strip paint from a part and it's Testors red enamel. Any help would be welcome. Thanks.
Posted by proosen on Saturday, December 18, 2004 12:08 PM
Paint removing.
Acrylic paint:
Any alcohol will take it away in a hurry, don't show your models with a whiskey in your hand! Big Smile [:D]
Enamels:
Mr. Muscle oven cleaner or anything with caustic soda in it, be careful as it harms the skin, eyes and pretty much any part of you Shock [:O]
Lacquers:
Brake fluid, please test on a scrap piece from the particular model being stripped as it can melt the plastic leaving you with a ill tasting styrene chewing gum Dead [xx(]
In all cases give it a good scrub with a old tooth brush and some detergent and rinse thoroughly afterwards
Good luck!
Niclas
Posted by Anonymous on Saturday, December 18, 2004 3:47 PM
Castrol Super Cleaner, in the purple bottle. Just soak the part in it for a day or so, then scrub. Use the usual eye/hand protection when dealing with the undiluted stuff. This stuff works great on just about anything, except resin.
Posted by Anonymous on Saturday, December 18, 2004 5:20 PM
Thanks guys I'll give it a try
Posted by midnightprowler on Sunday, December 19, 2004 7:35 AM
I use Simple Green to emove paint, and chrome as well.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
    January 2003
Posted by yardbird78 on Sunday, December 19, 2004 3:37 PM
I have used DOT 3 Brake Fluid to remove enamel from several models and, so far at least, have not turned any of them into "ill tasting chewing gum." There is always the first time. This leaves an oily film that must be washed off with soap and water. While brake fluid is not especially caustic to skin or lungs, it is best to wear rubber gloves and use at least some ventilation.
Westley's Bleach White, the whitewall tire cleaner, works wonders for stripping chrome from parts that you want to paint. Soak the part for 1/2 hour to 4-5 hours depending on the density of the chrome. Rinse with warm water and you are ready to go. Rubber gloves would be a good safety precaution. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
Posted by Anonymous on Monday, February 14, 2005 3:14 PM
wolfster - Hey, I have used lemon scented Easy off for several years on both enamels and lacquers.
    January 2005
Posted by jinithith2 on Monday, February 14, 2005 4:31 PM
Lemon scented Easy off, wgere do you get it and for how much moola?
Posted by STICKMAN on Monday, February 14, 2005 8:42 PM
I also have used Easyoff a few times and found it can make the plastic brittle,which could have been the age of the kits too. just thought i'd mention it.
    July 2003
Posted by saltydog on Monday, February 14, 2005 10:31 PM
i will also vouch for the easy off oven cleaner, as well as the castrol super clean. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    November 2004
Posted by thunderbearr on Wednesday, February 16, 2005 4:22 PM
Is that the Zimpro Lawn Mower? Dennis is a friend of mine!
    February 2005
Posted by RadMax8 on Saturday, February 19, 2005 11:40 PM
Hey man, automotive product. It's called Westley's Bleche-Wite whitewall tire cleaner. I've heard it takes the paint right off. I've got the same plight you do. tamiya Countach LP500, was running low on propellant and mussed the paint so i'll be trying this technique tomorrow. good luck!
    April 2005
Posted by ultraliner13 on Tuesday, April 12, 2005 1:00 AM
I use caustic soda in hot water. Dont do what I did once and use boiling water. the paint came off but the caustic soda became unstable and destroyed the model body.
    March 2005
Posted by philo426 on Tuesday, April 12, 2005 4:06 PM
Westley's bleach-white is my favorite paint stripper.It will not harm the plastic and works on most any paint.Just be sure to wash it with warm water to remove any trace of the stripper.It can be found in most auto parts stores.
