I normally don't build cars so keep that in mind.
I'm building this Nascar for a friend and I am almost finished with it, but I am having trouble getting the windows to stick in place.
The windows fit into recessed areas on the outside of the car body, so obviously I have to use something clear to glue them into place, I have tried Kristal Klear but as soon as I touched a window it popped right loose after 24 hours of drying time.
The glue stuck real good to the painted surface (which I thought would be a problem) but came clean loose from the clear window part.
I went ahead and popped the rest of the windows loose (with no effort at all) and cleaned the KK from all the surfaces so I could try something else.
Suggestions??
