Painting a model car
Posted by Anonymous on Sunday, April 24, 2005 9:20 AM
I thought I would double check with some of you expects before I get myself into trouble. I am painting a plastic model car. I will prime it lightly with automotive primer the product is called PLASTI-KOTE and then I intend to lightly paint it with a can of Ford Model Master Custom Lacquer System. In both cases priming and painting I planned on spaying the contents of the cans into my airbrush bottle and then apply it to the model. Any additional advise would be most appreciated. I think I can do the above without a problem. Thanks....
    July 2003
Posted by oldhooker on Sunday, April 24, 2005 11:39 PM
First of all, match all the paint you're going to use, ie: enamel/enamel, lacquer/lacquer, acrylic/acrylic.
Generally, if I want a mirror type finish, or a rubbed metal type finish, I'll proceed along the following steps:
(1) Wash the plastic with water and a small amount of dish detergent to eliminate any grease... (bare fingers should NOT touch the car body from this point on).... you can use a primer if you want to, but if you've cleaned it good there won't be much need for that. Spray the color paint in several light coats, so no running or orange peel occurs, then place under a box for 2 days.
(2) Apply Testors Gloss-Coat to the assembled body and place a box over it to keep dust/fiber particles from settling on it, don't touch for 4 days.
(3) Apply decals and let stand for 2 days.
(4) Apply another good coat of Gloss-Coat and place under the box for another 4 days.
(5) Lightly apply some automotive rubbing compound with a cotton ball to reduce the super glossy finish.
You can achieve a beautiful finish with raddle cans or an airbrush, but using different mediums of paint is terribly unforgiving. Enamel Primer, enamel color, and enamel clear coat.... the same with Lacquer or acrylic.
Hope this helps...
Frank
Posted by Anonymous on Saturday, April 30, 2005 5:20 PM
When i paint a car i will first wash it in warm water w/ little dish soap(where laytex gloves powder free when touching body from now on.)then i will prime the body with model master black primer wait a day then spray it with the body color wait a day i have never done decals so i just give i a coat o clear gloss wait a day and im done as far as the automotive rubbing compound its a grate tip that i will be using in the future.
