Removing Chrome Plate
Posted by Anonymous on Wednesday, June 1, 2005 8:44 PM
What is the best way to get the chrome plate off the plastic. I know it was in an older issue of FineScale but I can't remember which one. Thanks
Bryce
Posted by Anonymous on Thursday, June 2, 2005 12:02 AM
I've found Easy Off the easiest (Blue Can ) It will strip enamel paints, chrome and also will not harm most clear parts as other products may do. Get a container with a cover, place parts in to be stripped, spray away from yourself ( fumes burn ) cover and leave sit , about 2 hrs. and the chome will peel off. Use rubber gloves to handle parts and clean in warm soapy water with a small tooth brush. Don't reuse. Play safe and Happy Modeling.
    July 2003
Posted by lizardqing on Thursday, June 2, 2005 12:20 AM
I have had pretty good luck with bleach. Takes the chrome off right in front of your eyes. Only once so far has it not worked and that was on a 30 year old kit part, guess teh chrome was pretty happy being on it at that point.
    May 2005
Posted by nick31 on Thursday, June 2, 2005 4:37 AM
I tried DOT3 brake fluid recently and it worked OK. Didnt peel off easy peasy - needed a bit of scraping but it worked. The brake fluid was old though.
    May 2003
Posted by Martsmodels on Thursday, June 2, 2005 7:01 AM
Bleach - nice and clean and works every time, every household has some and you don't have to use special containers - just pour into a bowl and wash out afterwards.
Martin http://www.freewebs.com/martsmodels/
    July 2003
Posted by Stormbringer on Thursday, June 2, 2005 7:48 AM
The other thing you can use is Mr Muscle oven cleaner. Put the items into a plastic bag squirt some oven cleaner in and leave for 20-30 minutes, then wash off with warm soapy water.
HTH
Pete
Nolus Illegitemi Carborundum Keep the Pound! Down with the EEC and the Euro
    March 2004
Posted by SeaBee on Thursday, June 2, 2005 9:58 AM
I allways use household cleaner (with amonia) - the white stuff you clean the bath with! Over here, we have a "normal" cream one and a gel one - I founs a mix between the two works a charm. You mix them, throw you piece in there (I leave it in overnight), take it out, wash off the cleaner and let dry.
No problem!
    February 2005
Posted by RadMax8 on Thursday, June 2, 2005 6:43 PM
I use Westly's Bleche White whitewall tire cleaner. You can get it at the local NAPA in a gallon jug... best part is you can reuse it as long as you filter it out. It's only like $5 per gallon,. too
Posted by Anonymous on Thursday, June 2, 2005 8:11 PM
Thanks for the responses. I'm building Revell's new Viper SRT-10 and the chrome parts just won't look right.
Semper Fi
Posted by Anonymous on Thursday, June 2, 2005 9:53 PM
i just paint over mine
    June 2003
Posted by Jammer on Saturday, June 4, 2005 11:09 AM
Castrol Super Clean works great and is biodegradable. Takes off paint and chrome pretty quickly. It's also reusable. I ended up just putting a rubbermaid tub on the porch and rotate poor paint jobs and chrome out as needed. Just make sure you use gloves.
Doug
    May 2004
Posted by afulcher on Saturday, June 4, 2005 3:19 PM
Anything with ammonia will work.
Andy
