tire seams
tire seams
Posted by dubix88 on Saturday, July 5, 2003 5:05 PM
HEY,
I was wondering if any of you know how to get the seam out of the middle of the tire of a car. You cant really see it when the model is finished but i know its there and it is bugging me. Thanks for any help.
RandyTongue [:P]
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Holley on Saturday, July 5, 2003 6:06 PM
Randy,
I had to sand the tread off some tires once for a project, and I made a jig out of a bolt, nut, and two fender washers to sandwich the tire. Then I chucked it in a drill and ran it across sandpaper til all tread was gone. If you stopped short of making 'may-pops', that might work for you.
Holley When all else fails, read the instructions!
Posted by Wingman_kz on Sunday, July 6, 2003 8:07 AM
I haven't tried it yet but I read a tip somewhere about someone using disposable razors to shave the flash off.. I've found that some of the tires I just shave it off with a sharp blade, some I can trim with a large pair of nail clippers and the rest I chuck in a drill as Holley said and sand 'em.
But I've got a set of slicks now with a pretty nice sink hole in them and don't know what I'm gonna do about that.
Posted by dubix88 on Sunday, July 6, 2003 8:19 AM
HEY,
Yea, ive tried to shave it off and it leaves a flat spot in the middle while the rest of the tire has tread. I like the sanding technique.
Randy
Posted by wayne baker on Monday, July 7, 2003 3:38 PM
If you have a Dremel or its equivalent, get some used bits from your dentist and chuck that instead of the tire. go lightly around the tire with the bit. if you take tread off. it will look like you ran over inflated tires.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Anonymous on Thursday, July 10, 2003 12:20 PM
dubix88,
The technique I use is a nice sharp hobby knife to get rid of the flash and then sandpaper. You don't necessarily have to put it in a chuck(but if this works--great!). I use a piece of really coarse automotive sandpaper to give it the right effect. I prefer to sand the tread to make them look as though they've been on the road for a few miles.
Hope this helps!
Carlos
Posted by Anonymous on Tuesday, August 12, 2003 1:14 PM
sometimes you can use fingernail clippers to trim the flash off(depends on the size of the tire),then go with the sandpaper.I use 180 grit.
Posted by Anonymous on Thursday, August 14, 2003 10:03 AM
I hate two things in car modelin': the clear parts ( always too thick ! ), and these pesty tyres mouldin' flashes...!
A good trick before to start sandin'...Put the tyres in the freezer durin' a couple of hours to cool and harden them: it 'll makes the sandin' easier...!
And if it doesn' t work, try a more radical approach: cast the whole tyre set in resin...!
Posted by dubix88 on Thursday, August 14, 2003 12:31 PM
HEY,
I could do resin if i knew how and if i had the right stuff. I am too much of an ameture to do that. I dont even have an airbrush yet! Workin on that one though.
Randy
Posted by Anonymous on Friday, August 15, 2003 7:49 PM
ive herd about putting the tires in the freezer until there hard and sanding the tire
Posted by coldwar68 on Tuesday, August 19, 2003 3:01 PM
I tried what cferrero did and thought that it turned out well. It does look like the tires have had a few miles on them. I found that I had a use a new, sharp blade and just follow the tire and try not to "dig in" with the blade.
Jerry
I can picture in my mind a world without war, a world without hate. And I can picture us attacking that world, because they'd never expect it. -Jack Handy
