It is built as factory stock as absolutely possible.
Its got an 8 piece photoetched grill, and also a PE license frame.
(Click To Enlarge)
Made the plates of my computer.
(Click to enlarge)
fully wired and plumbed, the spark plug wires are in the correct firing order.
(Click to Enlarge)
(Click to Enlarge)
Added the valve stem from Piano wire, picked up the wheels from Scale Equipment Ltd.
(Click to Enlarge)
List of Modifications
Interior
Photoetched seatbelt hardware and seatbelt material from the Model Car Garage. Photoetched key and keychain hanging from the dash from MCG. The interior is flocked with Ken's Kustom Fuzzi Fur. The steering wheel is a kitbashed Tuff steering wheel and the "pistol-grip" shifter is also kitbashed from the nash bridge's cuda kit. The gauges sit under a simulated glass.
Exterior/Body
Was painted Copper and had two clear coats. The finish was polished with "The Treatment" wax. Simulated Vinyl roof, and Bare metal Foil. Scratchbuilt the antenna. Added homemade licene plates with photoetched license plate frames. Photoetched emblems were added from MCG. The grill is an eight piece photoetched unit.
Wheels/Tires
the tires are from Scale Equipment Limited, and were dullcoated. The stance in the front was modified to sit lower and be centered in the wheel wells. It also has poseable steering. I added the valvle stem to the wheels using piano wire.
Chasis
Brake lines were added with hook-up wire. The chasis has factory correct overspray. the driveshaft was scratchbuilt from aluminum tubing and has factory correct paint-codeing on it.
Engine Bay
the engine bay has spark-plug wires in the correct firing order. I scratchbuilt the spark plug wire looms. Has battery cables with two positive leads and the negative cable has factory correct engine overspray on it. I scratchbuilt the tie down clamp on the battery. I added heater hoses & brake lines coming out of the master cylinder. It includes secondary wiring to the coil, windshield wiper motor and to the alternator. Added the line from the windshield wiper resoirvoir and simulated the white plastic tie down clamps with contact paper. I also added the emision control hose from the valve cover to the carb. The wiper fluid reservoir is painted to appear half full. I also scratchbuilt the springs in the hood hinges and the hood release spring. Added a photoetched radiator cap. The engine block is spray painted with the exact same paint as the 1:1 is, & the hood has simulated under-hood insulation
Seven
