Whats the easiest way to attach wiring to the fire wall....?
Posted by ipms40049 on Saturday, September 24, 2005 4:33 PM
and like make bends and curves in the wiring.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by HeavyArty on Saturday, September 24, 2005 4:41 PM
Thin, soft wire or solder and superglue. Bend to shape and glue in place. All the wiring on my DUKW firewall and engine compartment was done this way.
Posted by ipms40049 on Saturday, September 24, 2005 7:56 PM
Thanks alot !!
    July 2013
Posted by DURR on Saturday, September 24, 2005 9:58 PM
also what i do is with the point of a blade make a small holejust deep enough to put just the tip of the wire in it with super glue that way it looks less like it was just attached but looks more like it has a home
    February 2005
Posted by RadMax8 on Saturday, September 24, 2005 11:38 PM
Could use a pin vise for that...
    July 2013
Posted by DURR on Sunday, September 25, 2005 7:06 AM
yeah but rad i don't have any vises i'm a good boyClown [:o)]
Posted by Anonymous on Sunday, September 25, 2005 9:21 AM
To attach wires to a firewall or inner fender, I do the following; Usually, wires on the real car are attached with some sort of metal band or plastic clip that is fixed to the firewall. The idea is to try to duplicate this idea.
- Drill a small hole (the smaller, the better) in the fire wall, underneath where the wire will be routed.
- Insert a 1/2" length of very fine black thread (or fine wire, fishing line, etc) into the hole and glue one end to the back side of the fire wall. (I use a .025" -.035" drill bit)
- Pass the free end of the thread back through the hole, leaving a loop.
- Pass the wire or cable through the loop.
- Tug on the free end of the thread, cinching the wire or cable snugly in place on the fire wall.
- Glue the free end of the thread to the back of the fire wall.
I hope this makes sense.
This method provides a neat and authentic appearance, completely free of any visible glue. The wire is held very securely, and by placing the 'clips' in the right places, the wire can be easily routed where ever you want it. It's quick & easy, and almost impossible to screw up. Works well for fuel lines and brake lines on the underside of the chassis, too.
