QUOTE: Originally posted by mkhoot
I made this tool from a couple of rubber washers, some threaded rod and some nuts from the local hardware store. I chuck ti up in a cordless drill and spin the tire while I sand it.
I have also made this tool. I put it in the drill press and it works great. Adds realisum to the tires. Don't sand to aggressive on tires with tread, you only need to knock off the shine. I use a sharp #11 blade to remove the flash from between the treads down the middle of the tires.
