CHROME PAINTING
CHROME PAINTING
Posted by Anonymous on Tuesday, October 4, 2005 4:00 PM
The standard modeling chrome paints don't give the SHINE I'm after. Will automotive-grade chrome paint (from auto parts shop) harm my plastic model? Any tips? Don't want to use BMF at this point.
Posted by Anonymous on Tuesday, October 4, 2005 4:04 PM
Use Alcad. It will give you a great shine, but is a bit expensive.
You can use automotive chrome paint, but not all work on plastic. Some types can damage the plastic, and some won't even stick. Use a test piece of plastic to see if it works. Some automotive lacquers can melt plastic, but I have never had this happen.
Posted by Anonymous on Tuesday, October 4, 2005 11:30 PM
Chico - The Alcad paints are the way to go. However, they require an airbrush and all the headache that goes with it. They are expensive and you'll need to practice, but when all is said and done, they are outstanding.
If you want to avoid the airbrush route, I highly recommend the Model Master Metalizer paints. The Aluminum paint with the gloss metalizer clear coat (applied after buffing) is a very, very good finish. I recommend you try the variety of MM Metalizers unless you are determined to go the airbrush route.
One other thing. If it's a part you can fabricate in brass, do that and have the piece chrome plated. Nothing looks like chrome like real chrome.
Just a few thoughts.
Andy.
Posted by Anonymous on Wednesday, October 5, 2005 6:07 AM
Actual chrome painting is way too expensive.
MM Metalizers should not be brushed on, especially aluminum. Spray on the buffing aluminum, let it sit for an hour. Then buff it with a soft cotton cloth and spray on the sealer. The more you buff it, the greater it will shine.
Alcad Chrome is the best way to go.
    March 2004
Posted by uilleann on Wednesday, October 5, 2005 6:45 AM
Have you guys seen this? And it wasn't even chrome plated! ;)
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=50555
"I may not fly with the eagles.....but weasels don't get sucked into jet engines!"
Posted by Anonymous on Wednesday, October 5, 2005 10:41 AM
How are these paints different from standard enamel paints?
