Paint thinner
Paint thinner
Posted by Anonymous on Saturday, October 29, 2005 7:04 AM
Hi, i am new to this and i was wondering if it is ok to use general purpose turpintine from the supermarket to thin my enamels or do i need the special thinners from the model shop?
Posted by Anonymous on Saturday, October 29, 2005 7:57 AM
sorry wrong section
Posted by Anonymous on Saturday, October 29, 2005 11:11 AM
Turpetine isn't the best thinner for thinning enamels. It will work, but I recommend that you purchase some ordinary mineral spirits. Mineral spirits are also cheaper.
Posted by Anonymous on Saturday, October 29, 2005 2:06 PM
Ok, what happens if turpentine is used?
Posted by Anonymous on Sunday, October 30, 2005 8:43 AM
Turpentine will cause enamels to turn into a very viscous liquid that can clog up your airbrush. For small jobs you can use turpentine, but for anything else I wouldn't.
    March 2005
Posted by Devil Dawg on Sunday, October 30, 2005 2:06 PM
Always use the paint manufacturers' thinner recommendations to thin your paints. I use general purpose paint stripper to clean my airbrush and bristle brushes, as it is much cheaper to buy (about $2.00 per quart can, versus $6.00 per pint can for Testors thinner). But, I use Testor's Airbrush Thinner for thinning my enamels, and I use Testors Thinner For Metalizers for thinning my lacquer-based stuff, as well as for cleaning it. I use denatured alcohol for thinning acrylics, as well as cleaning acrylics. General purpose enamel paint thinners and cleaners just aren't made for the types of enamels that we use for modeling. Some could actually attack the plastic, or cause the paint to come out looking like crap.
Hope this helps you out.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
Posted by Anonymous on Sunday, October 30, 2005 7:16 PM
well i got some mineral spirits but its called white spirits. Im not sure if thats another name for mineral spirits or not. If not im just going back to the model shop to buy some thinners.Thanks.Cool [8D]
Posted by rangerj on Monday, October 31, 2005 9:10 PM
As a rule of thumb it is usually best to use the thinner or reducer that is made by, or recommended by, the paint manufacturer. For example if you are using Testors paints use Testors thinner, if you are using Humbrol paints use Humbrol's thinner, etc. This will generally give you the best results.
    December 2003
Posted by thevinman on Tuesday, November 1, 2005 9:03 AM
QUOTE: Originally posted by rangerj
As a rule of thumb it is usually best to use the thinner or reducer that is made by, or recommended by, the paint manufacturer...
Sign - Ditto [#ditto]
