Painting Car Bodies, i.e. - NASCAR or classics
Posted by SNOOPY on Thursday, November 3, 2005 11:40 AM
I am starting to do a couple of cars. I have done a couple of airplanes and a couple of Sci-Fi vehicles but I have never done a car. I wanted to start collecting Nacsar Models and there are a couple of Classics I would like to build. Everything I read, shows you how to paint the body (outside) with nice even, equal distance strokes from an airbrush or paint can. A couple of questions though, all instruction or reference mat'l show painting the sides. When and how do you paint the roof and hoods? Are they done first or after the sides and what about over spray? Lastly, what do you do about the inside of the car body? On Nascar, would you paint a primer only then paint the outside of the car the color needed and just leave the inside primer color or what? Please help a new guy oout here. Throw me a big bone to get these projects rolling.
Scott
    August 2005
Posted by corvettemike on Thursday, November 3, 2005 2:13 PM
I paint the inside of the body, mask it off from the inside, and paint as usual.
Rise my brothers we are blessed by steel in my sword I trust...
Arm yourselves the truth shall be revealed In my sword I trust...
Havoc Models
    August 2005
Posted by eizzle on Thursday, November 3, 2005 2:49 PM
I would paint the inside whatever color the interior is, usually flat white i think? Then you can mask off the inside of it and paint the exterior. I try to start at the bottom when I paint, and I paint with a can, so it doesn't really matter, cause paint goes everywhere. i start at the bottom, and spray all the way around, then take it over the hood, roof, and rear deck lid. I try to do this to keep the strokes overlapping so they blend well. Just remeber one thing, multiple light coats are your friend!
Colin
 Homer Simpson for president!!!
    October 2005
Posted by Il Leone on Thursday, November 3, 2005 10:10 PM
Gotta be different here. I paint the exterior first. First get the body into primer. I give a light rubbing to the primer coat, just to get it smooth. Then start laying on the top coats. Now the real rubbing starts, I usually go for micro-mesh and wet sand like crazy. Most of the time, it takes to tries to get a good top coat. Finally, clear coat over the finish coat. Now I use the rubbing compounds, blue magic is a favorite. I think it is far easier to mask the outside then shoot the inside. BTW, if you get overspray on your nice exterior finish, a little blue magic and careful rubbing will lift it off. I do this for NASCAR and F1 projects. Alot of work, but good results.
Posted by SNOOPY on Friday, November 4, 2005 7:06 AM
Thanks for all the advice. I think i have a game plan now.
