Turning the wheels
    February 2005
Turning the wheels
Posted by RadMax8 on Saturday, December 31, 2005 1:59 PM
I'm building the 2002 Steve Kinser Sprint car and I want to put it on a base so it looks like it's sliding thru the turn. What would be the best way to go about making the front tires turned? Thanks guys!
Posted by jhande on Thursday, January 5, 2006 3:04 AM
I'm not familar with that model, but I am familar with real suspensions, anything that spins on the local track and I've been dabbling in car models from way back.
If I could see either a pic, diagram or something explaining how the kit goes together and how much custom building you are willing to do... Maybe I could toss a few ideas your way.
"If you're in control, you're too slow!Wink [;)]
-- Jim --
"Put the pedal down & shake the ground!"
    August 2005
Posted by eizzle on Thursday, January 5, 2006 9:28 PM
Like Jhandle wrote, it would be easier to say if there was a pic, but I think I can tell you a method you will probably be able to make work. When you put the part spindle (the part the wheel goes on) on to the rest of the suspension, like A-arms and the tie rod, if its possible to do this, instead of gluing them in, take your knife and heat it and then use it to make the pins the suspension fits to have a mushroom head, just take the hot blade and push it against the pin and it should do the trick. I hope this helps, good luck!
Colin
 Homer Simpson for president!!!
    February 2005
Posted by RadMax8 on Friday, January 6, 2006 12:07 PM
This kit is kinda interesting. I'll post pics when I finish re-chromeing the bad boy. I already turned them... you guys can tell me if I'm an idiot or not... Should be finished with chrome tonight so look for pics tomorrow!
