Question : Removing Decals
    January 2006
Posted by Hobbyguy on Thursday, January 26, 2006 10:57 PM
Can someone tell me what is the safest way to remove decals from a Diecast car?
    August 2005
Posted by eizzle on Friday, January 27, 2006 8:51 PM
You could try micro set and see if that takes them off or at least loosens them up. Hot water might do pretty good to. If your going to strip the paint you could just use to lacquer thinner, it will eat the decals and the paint right off of it!
Colin
 Homer Simpson for president!!!
Posted by jhande on Saturday, January 28, 2006 6:27 AM
Sometimes leaving a hot damp cloth on the decal will loosen it up. It might take awhile or even a few times of getting the cloth wet under the hot water.
If that doesn't work, you can try a product called GOOF-OFF. You can find it at Wal*Mart, in there hardware/paint section and hardware stores. Use it cautiously. It is meant for taking marks, glue from tape, and other junk off of painted walls and such, but if you rub too hard and long it will start to work through the paint (water based latex). Enamel paint seems to hold up better than water based paints. But it can dull the area that your rubbing if your not careful. But just buff it back out and wax.
-- Jim --
"Put the pedal down & shake the ground!"
    January 2006
Posted by Hobbyguy on Saturday, January 28, 2006 7:26 AM
Thanks for the info.
Howard
    July 2003
Posted by 72cuda on Thursday, February 16, 2006 2:49 PM
besides GOOF-OFF there is another product from Floquil/Testors I can't remember the name but it's used for models to strip, it'll get rid of the decals but you have to use very little because it also will strip paint off if left on to long
84 of 795 1/72 Aircraft Competed for Lackland's Airman Heritage Museum
Was a Hawg Jet Fixer, now I'm a FRED Fixer
 'Cuda
Posted by Anonymous on Saturday, February 25, 2006 11:23 AM
I believe that I read this in Fine Scale Modeler.  If the decals are water-slide decals simply take a piece of scotch tape and place it completely/firmly over the decal. Then...simply remove the tape.  I have done this before and it works great. If a piece of decal remains simply repeat the process.
Stretch5
Posted by Anonymous on Thursday, March 9, 2006 7:55 PM
Sometimes the markings are tamp printed which is a type of ink. In that case, stripping and repainting the car is the only way to go.
Posted by Anonymous on Monday, March 13, 2006 4:40 PM
Sandblasting.
If that doesn't work, dip the cars in acid for about three hours.  The decals will be gone - I promise.
    September 2004
  • From: Southern Maryland, right on the Chesapeake Bay
Posted by Likittysplit on Monday, March 13, 2006 9:39 PM
 AndyMarks wrote:
Sandblasting.
You're a genious. And a big help, too. Thanks.
    May 2005
Posted by Bgrigg on Monday, March 13, 2006 11:42 PM
I tried that GOOF-OFF product once. Accidently spilled some on my skin and next thing I knew I was sitting around, drinking beer and talking about hockey. Be very careful with stuff like that!
All kidding aside, if you're trying to save the decals, try Micro Sol, but if you don't care use a fairly strong masking tape.
So long folks!
