It's fine in most case. The only problem is flast paint cover usually less than Primer. So if your body is black and you want to paint it white, yellow or any light color, you will NEED primer.
Since you are new to the hobby, you should take a look at ScaleWiki. Mainly the FAQ
Good luck
