modelbuilder wrote: |
Ive had to cut out the "tunnel" on the
interior pan due to the lowering process and engine I chose. Whats the
best way to rebuild this? |
My quess for the "best" results would be to get a sheet of styrene and
cut out a funnel shape. Heat it just enough so you can roll it to
shape. Make it slightly bigger or taller than you need and trim it to
fit the floor pan.
Or you can opt for a custom console look just by using 3 pieces (2 sides & a top). Shape to fit your design.
You can hide any imperfections by either using flocking or actual material and lay carpeting in.
Just a few ideas while I'm drinking my 1st cup of coffee.
Yeah I know, 1:53pm... bad night.
