Even more help.....
Even more help.....
Posted by Anonymous on Wednesday, August 6, 2003 6:57 PM
Once again, the new guy needs some help! I was building a 1941 Willy's hot rod, and was airbrushing the main body. I did the top half gloss black, and bottom half gloss red. The first problem I had with this is masking the half that I wasn't painting. Any tips there? I ended up using tape, and when I pulled it off, some of the paint came with it. That was my first time airbrushing an actual project part. Any tips? Thanks!
Posted by Anonymous on Thursday, August 7, 2003 9:15 AM
Air Force_Guy,
There's a ton of different ways to mask. I've used anything from regular invisible tape to notebook paper, to stencils. The best thing that I've found to be "gentle" on the paint has been a name brand invisible tape--like 3M, and not the generic brand of invisible tape, as they not only can pull the panit, but also leave the glue behind on the model.
Another thing is to let the masked paint thoroughly dry before applying anything to it.
Hope that helps out a little!
Carlos
Posted by Anonymous on Thursday, August 7, 2003 9:19 AM
I forgot to mention this, there's an article in last months Fine Scale Modeler where a guy used Silly Putty as a mask. It was used on armor, but I'm sure there are other applications that this technique can be applied to!
Posted by Holley on Thursday, August 7, 2003 11:16 AM
AirForce,
There is some new painting tape out, not sure of the name, that looks like masking tape but it is blue. It is very low tack, reportedly doesn't pull off paint, and is affordable. I have never used it, but my friend says it is the best tape he has found. I have used damp newspaper as a mask with no paint lifting.
Holley When all else fails, read the instructions!
Posted by Anonymous on Thursday, August 7, 2003 12:47 PM
Thanks for all the help!
Posted by dubix88 on Thursday, August 7, 2003 1:53 PM
HEY,
I used silly putty on my Chevell to do strips and it worked great. The only problem is cutting the silly putty in straight strips.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
