/41 Willy's Hot Rod
/41 Willy's Hot Rod
Posted by Anonymous on Wednesday, August 6, 2003 7:35 PM
I was building a '41 Willys, and putting the breathers on top of the engine. Any tips for a new modeler about gluing butt joints like this? I'm trying to avoid using too much glue, and I want it to look clean (mine doesn't). Any help out there?
    January 2003
Posted by Hoser on Wednesday, August 6, 2003 9:11 PM
Super Glue.
"Trust no one; even those people you know and trust." - Jack S. Margolis
Posted by Holley on Thursday, August 7, 2003 11:22 AM
Like Hoser said, Super Glue. You can use an accelerator to dry the glue instantly.
I found a spray bottle of it at my hobby shop. Just be careful as it will harm some paints.
Holley When all else fails, read the instructions!
Posted by FITTER on Thursday, August 7, 2003 5:32 PM
You might try drilling a small hole on the underside of the breather and a corresponding hole in the valve cover. Use a small piece of brass wire (or a piece of a straight pin) held in place with 5-minute epoxy or cyanoacrylate. It can be applied from the underside so as to be inconspicuous. Not only will this method present a neat appearance, but the small parts will remain where they belong.
FITTER
IBTL
