First off,
to the forums! Pull up a keyboard and stay a while.
Modeling on a tight budget is tough. Always being forced to take shortcuts with the expense of tools and paints that would enhance the model, can be pretty frustrating. Can I suggest offering to help out more around the house for an increased allowence, also offering to do yard work for your neighbors for some additional cash? The goal is to get more money, and 14 is a fine age to start doing that. Okay, enough prodding, to your questions!
jhande has offered some great advice, I hope I can too!
mooble117 wrote: |
1.)How can i make the decals stick better and go on smother |
Questions 1 & 2 are related. The smoother the surface the better the decal adhesion. If you can't get a smooth finish the decals will "silver" because the rough surface allows air to get underneath the decal, and that can also cause the decal to fall off. I suggest clearcoating
before you decal to give the surface a gloss surface for the decal to adhere too. More on that in a bit.
Use a shallow bowl of tepid water, that's warm, but not too hot. This will help the adhesive on the decal loosen quicker with less loss of the adhesive in the water. Trim out the decal carefully and useing tweezers to hold on, place the decal completely in the water, but for how long? The instructions will offer something brilliant like "a few seconds". I would try 10 seconds, but you will need to adjust the time based on the size of the decal. Less time for a small, more for a large, that sort of thing. Next remove the decal and place it decal side UP on a piece of paper towel and let it rest for "a few seconds" again that time will need to flex with the size. This allows the adhesive to become fluid and you'll want to poke (gently) at the decal to see if it moves freely. Next use those tweezers again to hold the backing sheet, slide the decal onto the model. You may want to put a couple of drops of that decal water on the model to assist is sliding the decal in place. Once you've got it where you want it, take a piece of paper towel (a torn off corner will suffice) and "wick" away most of the water. You might have to do this a few times. Then use a moistened Qtip and roll the tip (like a steamroller) over the top of the decal to push out the excess water. You can also use a brush. Gently now! The decal is soft, fragile and easily moved! Once the water has been removed, go away and let it dry. Don't touch it, don't even look at it! Give it at least an hour to dry. Then carefully examine the area. If you do see some silvering, take a very fine pin and poke the decal to relieve the air. Then take white vinegar and brush on a little using a flat tipped paint brush. That will help re-soften the decal and hopefully you can squeeze out the remaining air. Once you're happy with the decals, clear coat it again to seal in the decals and give them that "painted on" look.
mooble117 wrote: |
2.) would any clearcoat be good when i am finished? |
Yes, and no... Brushing on the modeling type clear coats is difficult without leaving brush strokes. This is where you'll want to invest in rattle cans. One idea would be to use Future Floor Finish, which is an acrylic paint really. It has good self leveling tendencies so it
can be brushed on (use a wide brush with fine hairs), and I've heard that some people actually use it on their floors. You can read about it
HERE.
mooble117 wrote: |
3.) Do i need to thin the pai(n)t at all? |
Depends. I need more information about what kind of paints you use. If you're stuck brush painting I would suggest enamel paints and thin them with some paint thinner (other people will have to help here I use acrylic paints exclusively!). Thinning paint helps the paint flow better, and better flow is a smoother surface. You don't need to thin for painting small pieces like engine parts and such.
mooble117 wrote: |
4.) With the other two models, the glue (testors non-toxic cemet(which
comes in a tube, link at bottom of page)) caused the paint to come off,
causing; a. white spots where the plastic shows through and b. paint
smearing onto other parts of a differint color. How do i avoid that? |
I would use a liquid cement such as
Testor's Liquid Cement or
Tamiya Extra Thin over the tube adhesives. A LOT easier to work with and excess cement evaporates away. Careful as it's solvent based and too much glue leave gluey fingerprint marks. Also try to avoid gluing painted parts, the glue will smear the paint every time.
mooble117 wrote: |
5.) a lot of parts require painting one part, for example, satin brown,
and other satin gray. What is the best way to do that (masking, using
fine brushes etc.)? |
Depends on the area to be paint. Mask large areas, fine brush for small. Also Google "dry-brushing" for this technique. It can really enhance engine and dashboard details.
mooble117 wrote: |
6.) how long should i wait for the paint to dry before gluing to parts together. |
I would try painting AFTER glueing, but that is sometimes difficult. I would wait overnight and then scrape off the paint on the areas that get glued together.
Read through the forums, also go and join up on
http://scaleautomag.com/ for some more auto related tips and ideas. Slow down and enjoy the build, rather than rush through it and not like the end result. Airbrushing is highly recommended and is normally expensive. If you have a Harbor Freight close by, go and check out this
AIRBRUSH KIT. Frankly it's not a very good brush, but it's cheap, it does spray large surfaces better than a brush paint job can. I'll even go so far as to say it's better than rattle cans! And yes, I do have one! I use it for clearcoating Future with. I bought the kit for the bottles and hose actually and the airbrush was kind of a bonus!
The kit comes with a propellent can adapter, but you can also buy tire chuck adapters and buy a large truck tire and fill it for free at the local garage. That should get you enough time to spray one model. Bonus if your dad or neighbors have a compressor they will let you use. While you're at Harbor Freight grab a pack of
THESE. I have a set of these and use the self locking tweezers for decals, and the thin bent ones for positioning small pieces.
Good luck and don't be afraid to ask more questions. There are a lot of talented people here who like to help!
