I'll try to help the best I can with the few flocking jobs that I've done so far.
shelbyguy wrote: |
One car will be "showroom new" and I was
wondering if the ejector pin marks on the bottom of the floor will show
through the flocking if I don't fill and sand them. |
The ejector
pin mark will just slightly show as a recess. Flocking goes on fairly
thin.
On a related note, the other car will be a junker with some
of the carpet worn away; |
After the bonding material (enamel
paint in your case) has dried, you can rub some of the flocking away.
I want the rest of the carpet to be really rough. I
roughed up the floor with a Dremel tool to the point that the effect is
pretty subtle and would look great painted and drybrushed but am
worried that if I flock it the roughed up areas they may NOT actually
show through if the flocking material or the enamel paint I plan to use
as an adhesive is too thick. Is this a legitimate
concern? |
Yes it is. Flocking is nothing more than small fibers
of fabric. Think of tiny thin thread cut short. All you are doing is
dropping it onto an adhesive. Ever see the fuzz inside a car console or
glovebox? Flocking is used in many real world applications. But in our
modeling world applying it just the way we want it isn't the easiest of
procedures. You might be able to use tweezers to help the flocking
"bunch up" in the roughened up areas or else it will just lay smooth in
the paint.
I've never flocked before so I don't know how relisiant this
stuff is (I'm using the actual flocking material you buy at the hobby
store... maybe some people use other stuff??). |
Flocking is
flocking, it's only made out of three different fiber materials, two of
which are usually too expensive to see their way into the hobby field.
They have to do with mildew and UV control... things like that.
One more question since I'm here... can you piant
flocking AFTER it's been applied so you can exactly match the interior
color, or would this just make a nasty looking mess of it? |
I used a white flocking for carpenting on the interior tub. I then
sprayed a few light mist coats of the intended interior color. I left
it for a few days to dry. It didn't turn out too bad. The key I think
was the very thin mist coats. It did result in a more flat or matte
finish compaired to the rest of the interior pieces which was fine,
since carpenting usually does look different than leather or vinyl
seats and door panels LOL.
It might be worth experimenting on a piece of scrap, even a little
piece of cardboard. Just to get the feel for flocking. Oh, as a note,
when using enamel paint as an adhesive it is best to use flat for
cosmetic purposes. The gloss has more adhesive powers but leaves too
much of a shine through the flocking. Unless you don't mind shiney
carpets?
Good luck and have fun!
