White on Tires?
    August 2006
White on Tires?
Posted by Striving on Sunday, August 20, 2006 2:04 PM
Just wondering what paint is good to use to paint the logos/markings on rubber tires? In the old days I used testors, but it seems to never dry. Whats the best way to do this?
Thanks all.
-BruceBig Smile [:D]
Posted by jhande on Sunday, August 20, 2006 4:13 PM
Hey Bruce, I'm an old Testor fan from way back also. I found using my wifes hair drier on the really thin coat helps some.
She has the type with one of those fold out stands, so I just turn it on and forget about the tires while they toast on low heat for awhile LOL. The paint can still rub off so be careful. I understand if you spray a coat of clear over it that when done that helps some. I'll be trying that soon.
Wink [;)]
-- Jim --
"Put the pedal down & shake the ground!"
    August 2006
Posted by Striving on Sunday, August 20, 2006 6:34 PM
Cool, thanks. I did some searching and also saw some say to use Acrylics. That they dont stay as wet on the rubber. I'm gonna give that a try too.
Appreciate the feedback.
-B
    August 2003
Posted by wasjr on Sunday, August 20, 2006 9:57 PM
Try Whiteout.  I always prefer to find the brands with a sponge applicator. There are also some brands with brush type applicators and some guys I know uses the pen type  Some friends use a tooth pick to apply it with.. Either way or type container, if you goof up you can just wash it off with water as soon as you goof, let the tire dry, and do it again. You can do this either before or after it is mounted on the painted rim.   Practice makes perfect
    August 2006
Posted by Striving on Sunday, August 20, 2006 10:20 PM
Cool idea!! I will try that.
    June 2006
Posted by georgebluhm on Monday, August 28, 2006 9:30 PM
You might try this!!!
My wife does tole painting and uses a brand called Delta Ceramcoat.
It is an acrylic paint, washes up easy, covers great and usually covers in one coat.
It can be found in most craft stores(Michaels,AC moore,HLS,ETC)
I think they even have it at Wal-mart.
It can be had in about 200 colors
Hope this helpsSmile [:)]
