Anyone building 1/6 Revell Plymouth Hemi Engine
    December 2005
Posted by Count DeMoney on Sunday, October 29, 2006 3:33 PM
If anyone is building this kit, I have a recommendation.  Before you complete the #6 instruction (Blower to the blocK), I suggest you think about looking at step 10 and consider gluing the "distributor shaft" only to the engine.  The shaft only, not the distributor itself.  It is a bear to get in after the blower is attached to the block.  Another quick hint, many people have had strip out problems with some of the screws.  I used a jewlers type screwdriver with a very hard tip to start the first few threads in.  Then, I swithed to a high quality craftsman #1 phillips full sized screwdriver to tighten.  I didn't have a single problem doing it this way (:>
