Thanks for your comments so far! I plan on painting the body a gloss white, exactly as specified in the kit. Originally I had wanted to paint it black but it turns out I had already painted part of the undercarriage white to match. Oh well.
I actually updated the gallery and added some photos. I've reached the point where I'm masking/painting/installing the headlights and brake lamps. Almost every car model I've built when growing up calls for painting the recessed area a metallic color and attaching a piece of clear red plastic. This kit was no exception.
I have several questions about this:
1) How does one secure the plastic in the painted recessed area? Do you leave the paint off the edges and put a ring of cement around it? I tried using superglue but the paint dissolved and it clouded the plastic. I thought of using thinned white glue. Will that be a strong enough bond? Would your answer be different for my signal lamps, which are backed by clear orange (tamiya) paint?
2) It seems like it'd be easier to spray the body, then hand-brush the metallic recessed parts, and then put the lamps on. This seems like it can be accomplished without putting any masking tape. Is that the best way? What order do you guys prefer?
Thanks again in advance, I'm really looking forward to closing this sucker.
Jeff
