Seeing as you didn't reply to your old thread after you got two very goood pieces of advice, I have some trepidation as whether or not to answer you here.
I will anyways, stick with Scale Motorsport's decals. They are well printed, consistent, easy to work with, shrink with application of heat (blowdryer) react well to micro-sol and set, take clear coat nicely, and relatively cheap and easy to get. If you need them but don't have access to a dealer, order them right from their website at $8.00/sheet, the amount you get should get any average modeller through two or three builds.
