Painting the body
Painting the body
Posted by Anonymous on Monday, February 12, 2007 8:12 PM
I am new to model building, and have a few questions:
1) For the cars, do you guys use an airbrush for everything? Or just use a regular brush for the interior and the airbrush for the car body?
2) Alot of these modelers use primer for the car bodies and then wet sand the primer and the final paint color before waxing the body. Is this necessary, I dont want to mess the paint up. I got this method from www.brianscarmodels.com.
3) lastly, whats airbrush do you recommend that I should use that I will not be able to outgrow when my skill increase?
    July 2003
Posted by Model Grandpa on Monday, February 12, 2007 10:10 PM
I personally airbrush as much as I can.  I've just never been able to lay paint on very well with a brush.  I only use a paint brush for small details.
You should use a primer on your models. I will do a little sanding before I start painting.  Need to start with a good base if you want good final results.
There are a lot of good airbrushes out.  I have used Badgers and Paasche's with good results.  My current airbrush is an Iwata Eclipse HP-CS that I really like.  It sprays well and is easy to clean up.  My suggestion is to buy the best airbrush in your budget and practice, practice, practice.  Don't forget you'll need a compressor too.
Regards, Dan Building Scale Models At The Speed Of Dark
    May 2006
Posted by F1champ on Monday, February 12, 2007 10:44 PM
I just use Tamiya spray cans for my model bodies. I lay down a primer coat sand it ncie and clean and then put down a second coat to get it smooth. After that I do plenty of coats of the actual body color so that when I start polishing I don't go through to the primer. Then it's some fine and finishing polishing compond and maybe wax depending on if i'm lazy or not.
    July 2003
Posted by Model Grandpa on Monday, February 12, 2007 11:13 PM
One other thing about your primer, it serve as a micro filler.  It helps fill it all the micro scratches before painting.
    December 2006
Posted by 387PetePilot on Thursday, February 15, 2007 2:31 AM
I airbrush as much as possible but I do a lot of emergency and truck models for people so i have just as much time brushin by hand. for bodies i always prime it, sand it then color coat then 2 good coats of clear, and i wet sand the clear before i wax it. i use automotive paints most of the time so after the wetsanding is done it looks like a mirror
Josh Duell FF @ Riverside Vfc If Im not found behind the wheel of my truck, Im home passed out!
    October 2005
Posted by Il Leone on Saturday, March 3, 2007 12:59 AM
1.  Paint the exterior first then the interior.  Much
easier to mask that way.  If you get some bleed through on the
interior, you can polish it out.  I airbrush both.
2.
My method?  Polish it!  I smooth out the surface, plastic or
resin.  Then lay on a good coat of primer.  Grab some
sandpaper and water then start polishing.  When it is smooth as I
can get it, lay on the paint.  Sometimes need a couple of coats of
primer to get it right.  Same story with the paint.  Paint,
polish, repeat.  When the paint is glass smooth, go for the clear
coat.  I really let the clear wick out before I mask for the
interior.  Spray the interior then get the polishing compounds
out, Mothers, blue magic and others.  It takes a long time to do
this, but the results are worth it.  When you get the clear
polished and waxed it is awesome to see the car glow!
3.  See my previous post on airbrushes.  Bottom line,
get one you like!  After 20 something years, I finally went to a
dual action.  I love it, but it is really hard to get it to work
like I want it.
Posted by Anonymous on Wednesday, April 18, 2007 4:30 PM
Hey,
 I'm soon going to start on my first Motorbike and I'll be trying to attain a nice finish.
 Firstly I have some questions I'd like to ask:
I know all about priming, sanding, priming until it's smooth. Apply thin layer of base colour, let it dry, apply a slightly heavier coat...let it dry and then sand before applying 2 or more layers of the base coat...
 Now, can you recommend some products to finish it? Polishing compounds and wax and roughly what each of them do? What's the difference?
 Also, when working on a model with 2 base colours, what's the order of progress? Do I get up to the 'compounding' stage, then mask and apply the second colour (repeating the same process as the first) then when both are dry, apply the rubbing compound and wax? Or is it different?
 I'd be very greatful for some answers as I hope to start this project in the next couple of days...cheers,
 Jake Eaton
Posted by Anonymous on Thursday, April 19, 2007 10:33 AM
Can anyone help? I figured this would be the place to come :)
 Thanks in advance!
    January 2006
Posted by wolfpac on Thursday, April 19, 2007 5:20 PM
Check this "how to" out.
http://www.badscaleracing.com/forum/viewtopic.php?t=1634
If you love your bike let it go. If it comes back to you, you've highsided. http://public.fotki.com/luke76/
