You could section the back pillars, it would just be a little tricky because there's not much plastic to work with at the bottom where you'd make the cut. Also, this type of chop leads to a raked roofline, lower at the front. with such curvacious body lines this may not be too noticeable, especially if you keep the chop mild. I would advise restraint on the angle you cut out at the back, it's really easy to cut out to much, then you have a gap to fill and a weak joint. Regarding your other modifications, can you post some photos so we can see what you're up against? If not, just describe the isssues in detail. By the way, the whole A, B, and C pillar thing confuses me. Does a '51 have a pillar behind the door, or is that just the window frames? Why couldn't they call them F, M, and B for front middle and back? Stupid auto industry. |
