Decanting Paint
    March 2006
Decanting Paint
Posted by grhornet on Tuesday, June 19, 2007 9:21 AM
Since I have started to build cars, I have heard about decanting canned paint.   What is the purpose of it and how do I  do it?         Thank You
building C-121 RF-F4C
Posted by proosen on Tuesday, June 19, 2007 9:29 AM
The main purpose is to gain better control over the flow and a good side effect is less over spray thus getting the paint to last longer.
Use a thick drinking straw about the size of the nozzle, cut it to get a shorter bit.
Put the straw over the nozzle, hold the end down a suiteable container and spray away. The paint you get out in the container needs to gas out for a while before you put on a lid. I usually use a film container with a little hole in the lid and leaves it over night to gas out properly before putting on a whole lid.
Now you you can use it as is in your airbrush or maybe thin i a little more, normally not neccesary it's fine as is.
Good luck!
Niclas
    December 2006
Posted by marioc on Tuesday, June 19, 2007 4:03 PM
I agree with the way explained, I like to add the following tip.
After decanting the paint will keep some amount of the gas and pressure, this will make difficult to deal with. With Tamiya TS paints I use to add little amount of lacquer thinner, which will do  the paint stable letting you shake...etc.
Mario Covalski
Editor
http://www.modelersite.com/
http://www.modelersite.net/
Mario Covalski Editor http://www.modelersite.com
