Likittysplit wrote: |
proosen wrote: | Wow, what a (Super-)Nova! Looks like you did the BMF-before-paint-trick, the Super Sport emblem is a real killer! The whole car just screams beautiful, look at me..... Niclas |
Thanks for the compliments, Nic. No BMF on the emblems, they are photoetched pieces from the Model Car Garage. This set has so many different parts that add so much detail I feel it's a "must have" for this model. |
I can sure see why you push for the PE-set it looks gorgeous.
The reason I asked is that you can achive about the same results with BMF and a little patients.
This is how the emblems turned out on my '67 Coronet. First primer, then a slightly big piece of BMF and on to the top coats. After the paint is dry carefully rub the paint away with a chisel-shaped match stick dipped in some thinners and then a quick rub with some polish and you're done.
Niclas
