Revell 50's Chevys
    July 2006
Revell 50's Chevys
Posted by carguy on Friday, November 9, 2007 12:47 PM
Just picked up the 3 pack Hot Rod/ Revell 54-55-57 Chevys off Ebay. I have mostly been an AMT model buyer (we all seem to prefer one over the other don't we?), and have built a few 50's Chev's of AMT pedigree, including the more recent 57 Chev with the opening trunk (a fine kit). I am more of a Mopar guy and also in to 30's to 50's Fords, but the 3 pack was too good a price, and I really wanted a 54 Chev kit.
 I always wanted to model a 54 Chev, simply because everyone has seen a 57 in plastic or 1:1....so common, it is almost boring. Little like the 60's Mustangs, just so common they are hard to do to the point they will really be noticed.
 Anyway, anyone built these Revell versions and got any tips/ warnings about them?....not in a negative way, but every kit has it's isiocyncrasies, I guess.... I plan to do them relatively "stock"....
Bill
    May 2005
Posted by Bgrigg on Friday, November 9, 2007 2:36 PM
If all you've built is AMT then you'll enjoy the Revell kits. Not much flash, usually better styrene than AMT and better details.
So long folks!
    October 2003
Posted by mitchum on Friday, November 9, 2007 6:41 PM
Are you sure you're talking about the same kits he is? The '54 won't be too bad because it doesn't have all the working and opening feature the '55 and '57 have but it'll probably stilll have  some flash issues.
The '55 and '57 kits originally came out in the mid-sixties and had opening doors, hoods and trunks with the '57 having some of the worst engineered hinges in the history of plasic kits. The '55 came later and at least the hinges worked pretty good. The '55 also (like the '56 sedan in the same series) had seperate side chrome trim that made my conversion of them into dirt track cars much easier back in the day. {not to mention doing '57 Black Widows three decades before the model companies discovered it using '56 roof and doors, '55 Bel Air sidetrim and '57 front and rear ends).
The '55 can at least be built with the opening panels option but I don't recomend the operating windows or the hinges of the '57 to anyone but masochists. The AMT has much better body proportions and you're gonna wind up glueing the doors shut anyway.
    March 2005
Posted by philo426 on Friday, November 9, 2007 7:57 PM
Here is my Revell '57 Chevy.All the panels open up and the fit is pretty good.The front suspension must be assembled with care but not a bad kit
    March 2005
Posted by philo426 on Friday, November 9, 2007 8:05 PM
    March 2005
Posted by philo426 on Friday, November 9, 2007 8:10 PM
    September 2006
Posted by mr moto on Friday, November 16, 2007 7:31 PM
The only real problem is that SOME Revell kits - and you never know which ones, it depends on when they were molded - are very sensetive to lacquer paints. Much more so than AMT, etc. So if you typically use paints like Krylon, Duplicolor or other automotive paints test them first on an unused scrap of plastic from that kit or you could end up with a crazed paint job!
The modeler's rule of thumb: The worse it smells, the better it works!
