New to models - any advice?
    February 2008
Posted by Raist23 on Monday, February 18, 2008 9:29 AM
Hello Everyone,
I cant say I'm totally new - but at least in the sense that I now seem to have the time to dedicate to try to do this right. Built models in the past - but no patience and always tried to rush it..
I'm currently working on the Honda Repsol Honda RC211V. I do have an airbrush which I will try at a much later date since I'm not very good at it, so just focusing on using a brush right now.
A few questions - Does anyone out there still use this method? I know you might use brushes for certain things - but what about an entire model, or what parts do/dont you use for a brush? I do notice that with the brush sometimes I get high spots or brush strokes or it builds up in areas with a joint, can you sand these out? Does this just take practice to avoid?
What paints are the best? I have seen Tamiya, Testers and Model Masters at the local hobby store.
When do you usually use primer?
What are good brushes to buy?
In your opinion what are the best models to buy? Brand I mean?
Thanks
    February 2008
Posted by enemeink on Monday, February 18, 2008 1:38 PM
I've found that using a brush on most components can be a good thing ans they can add texture when needed. say like the engine block or interior carpet. the only time i don't use a paint brush is on the body of the car. or any outward facing surface, unless you want that kind of texture. If you don't want to use the airbrush you could always go to your local automotive store a pick up a small can of spray paint. you might be limited in the color you want to use though. and primaring is a good idea if you go this route. some paints might eat the plastic.
as far as paints go i'm partial to Testors. only becuase I've been using them since I was a boy and never really tried anything else. so i may not be much help there.
my brushes i get at my local arts and crafts store in the discount bin nothing special but I love a very soft bristles for detail work.
"The race for quality has no finish line, so technically it's more like a death march."
    January 2008
Posted by acmodeler01 on Monday, February 18, 2008 1:56 PM
I mix it up a bit, usually using tamiya acrylics with my AB and testors for small detail painting. I use primer every time I paint a body. I found that tamiys fine white is probably the best, very smooth and forgiving. The same applies for spraying a body; again, I use tamiya which gives an incredible finish and is forgiving and easy to use.
As far as kits, I usually purchase based on subject. If there is the same subject available from several manufacturers, I will probably choose tamiya first, then fujimi, then revell. The japanese mfrs usually don't inculude engines, so if that is important, then you may want to look at another company.
HTH, good luck
