- Member since
January 2005
Posted by fantacmet
on Sunday, May 11, 2008 11:30 PM
Yes and sort of yes. The process is ALMOST the same, the only difference is, you use laquer thinner to thin fingernail polish since that is all it is, is a specially formulated laquer. You also have to be concerned about a proper barrier beneath it so it won't attack the plastic, but other then that the process is identical. You can get some spectacular finishes with fingernail polish with just a little extra work and very little effort. Plus colors you can find nowhere else.
