Advice on part making idea
    December 2007
Posted by VIPER0177 on Friday, November 14, 2008 2:43 PM
 I have an idea to make a part for my B-52H and I need some advice on if it can/will work. Ok here's the deal I need an ecm/radar fairing from my B-52G on my B-52H why AMT didn't put it there I don't know as both have/need it anyway. What I want  to do is use alum foil folded over 2-3 times to make a mold of the fairing I need then fill the mold with shaved plastic from the kit put that in the oven till it melts and fills the mold. Has anybody tried this before? If so will it work? If it works what temp do I cook it at? The part I need is a rather simple looking lump on the aircraft so I this idea won't work any ideas on what will would be great. Thank You.
Cluster bombing from B-52s is very, very accurate. The bombs always hit the ground.
    June 2008
Posted by Hans von Hammer on Friday, November 14, 2008 9:37 PM
For a small part like that, I'd skip the oven and heat the foil with a tea candle.  You'll have more control and can add a bit more plastic if you need to to fill any airspaces that form at the bottom of the mold.  Make sure you have more shaved plastic than you think you'll need, about double the amount...   It's trial and error with this process, so don't give up on it after a couple tries...
    March 2005
Posted by mfsob on Saturday, November 15, 2008 7:10 AM
I dunno how big the part is, but I would think taking an appropriately-sized piece of solid plastic stock and sanding to shape would be easier (and probably safer) than making a mold and fooling with molten plastic. It's amazing what you can create with sanding sticks and a little patience - I made a 1/144 IJN torpedo out of a piece of sprue of the right diameter, trimmed to length and then just sanded to get the rounded nose on one and and the tapered rear on the other end:
    June 2008
Posted by Hans von Hammer on Saturday, November 15, 2008 2:19 PM
I've been thermo-forming and vac-forming my own parts for a long time mfsob, since I was about 13 or so and I can promise you that it's easier and faster than sanding by leaps and bounds.. Sure, you gotta be careful or you may get a burnt finger now and then, but the chances of suffering any injury needing more medical attention than the bathroom medicine cabinet can handle is extremely low...  You run a greater risk of injury using a hobby knife, soldering iron, or Dremel tool than you do thermo-forming...  So unless you have a propensity towards stirring molten styrene with your fingertip, don't sweat it...Wink [;)] It's no more "dangerous" and only slightly more difficult than stretching sprue for radio antennas...  Besides, if it's turned into a liquid thin enough to spill, you can bet that it's also on fire...
    October 2003
Posted by ModelNerd on Saturday, November 15, 2008 10:39 PM
Can we see a picture of the item you want to make?
- Mark
