1/100th scale Space Battleship Turret Scratch
    April 2008
Posted by smeagol the vile on Monday, June 15, 2009 2:42 AM
This is for my  Gundam F91 master grade kit I'm working on /forums/1148743/ShowPost.aspx#1148743
Ill copy my latest post over there to here, because I'v done significant scratch building (all in one night, took about 2-3 hours so far)
While im waiting for my airbrush I have done ALOT of work on the base of this thing. I have started hand brushing the base, I primed it with handbrushing.  The pipes arent done yet, I'm going to give it all a black wash, but I painted all the recesses wtih the darkest green I have for depth
Instead of using the base as the stand like it was intended I decided to use some of my styrene to build a light turret for the ship(base).  The cannon itself is styrene like I said, the Barrel is PVC pipe.  I want to put a dust cover over it, but I'm not sure where to start doing that.
I cut the peg from the base of the Arm that attached to the stand so I can glue it to the bottom of the turret so it can actuially spin.
    April 2008
Posted by smeagol the vile on Wednesday, June 17, 2009 2:46 AM
Well, I have been working alot more on this, its taking ALOT of sanding and priming and puttying.  Alot of small crappy seams and imperfections that I need to fix, its going to take a while.
I took the arm off of the action base, cut the raised edges except for those on one side, slid it into the PVC pipe then measured the size of the notch at the base of the arm.  I then used my razor saw, dremel, and file to cut out a notch that width.
I then slid it back on, and super glued it in place so instead of it being forced into place it can raise and lower, like the turret will beable to turn.
As far as the turret turning, I ordered clear Styrene rods for displaying kits, Im thinking of cutting a hole going from top to bottom in the center of the turret and using the rod to support the mech as well as allowing the turret to turn, but I might not, what do you guys think?
Also, what do you think about scribbing some pannels onto the turret like on the base, yes or not? Also again, should I put some small search lights on the top of the turret?
    April 2008
Posted by smeagol the vile on Tuesday, June 23, 2009 5:14 PM
Ok, I'v made alot of progress IMHO on the cannon.  Using some lineart as a guide
While thats not the type of cannon Im using (thats a smaller variant) I took some of the designs for the targeting and such aspect that are coming off of the gun.
I'M still trying to come up with more ideas for what to go inside the turret
Posted by Jim Barton on Tuesday, June 23, 2009 6:32 PM
There's a young man who's a member of IPMS Craig Hewitt who loves to build Gundams and such. He would love this!Thumbs Up [tup]
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    October 2008
Posted by bsyamato on Wednesday, July 1, 2009 3:16 AM
seems good..
only the cannon barrel can be too large
