landing lights
    January 2010
landing lights
Posted by moose0005 on Sunday, January 31, 2010 3:20 AM
i have several models i want to add landing lights to i dont know what sizes to use for 1/35 scale 1/48 and 1/72 scale  models. if anybody can help please help.
    August 2006
Posted by HawkeyeHobbies on Sunday, January 31, 2010 7:55 AM
Research. Time to let Lord Google help you in locating images of what you want to replicate. Say for instance you want to make landing lights for a fighter. Start by doing an image search for that subject. Find reference photos. Also look for walk around photos, a visual documentary of the subject which was taken in all likelihood a fellow modeler.
Once you have your references, its time to source the parts or components to make the parts. By comparing the images and the model itself you can estimate the size of the lamp. A trip to your local craft store or model railroading shop can provide the lenses and in most cases everything you need. At the craft store you will find items of use in the beading supply aisle as well as the doll and doll house aisle.
Don't be afraid to tackle making you own either, from supplies you already probably have. I made these from fuel tank and bomb casings along with some light brite pegs, but clear sprue can be used as well.
Nifty spot light for an aircraft...
A landing light can be made from a piece of square stock cut. Cut a thin slice appropriate for the thickness of the housing then drill a hole in the center. Insert a piece of clear sprue into the hole. File, sand and polish into the final shape.
Gerald "Hawkeye" Voigt
    August 2008
Posted by tankerbuilder on Saturday, February 6, 2010 4:00 PM
Hi, I don,t usually build many planes. When I do I use the cheapest type of toothbrushes that I get at DOLLAR GENERAL. They can be gotten on clear,red and green as well as a smoke color.The toothbrushes can last for probably many projects if you don,t use them up with auto work.   Tankerbuilder       P.S. they take a nice shine too!!
Posted by oldthudman on Saturday, February 6, 2010 5:20 PM
For MV lights, ie headlights, landing lights here's a site that gives sizes vs scales...........
http://www.hubhobbyshop.com/hint32.htm
UNT Eagles; Veteran USAF
