C-75 - (Boeing 307) 1/48 WIP
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, August 31, 2010 9:48 AM
I have been planning this one for a long time and finally got started on it.
It is based on a Revell 1/48 B-17E.
Pic 1 - LARGE set of plans - Paul Matt drawings.
Pic 2 - patching up the slots. The C-75 has slots at the leading edge toward the wingtips.
Pic 3 - major surgery. The C-75 has no superchargers.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, August 31, 2010 9:52 AM
I plan to vacuform the fuselage. Here's my homemade vac machine.
    May 2009
Posted by Pawel on Tuesday, August 31, 2010 10:07 AM
Reporting to the moved thread! Nice machine. I built similar one years ago, but only did a few canopies on it, otherwise it just sits there unused - kinda pity. But still it COULD be used when the need comes. Question is: is your machine going to handle a fuselage that big? That boeing is pretty hefty in 1/48. Anyhow, I'll be watching, good luck and have a nice day
Pawel
www.vietnam.net.pl
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, August 31, 2010 11:13 AM
I will need to build a new larger frame to hold the plastic, but that will be no problem, just $7 at the hardware store..
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, August 31, 2010 2:41 PM
Pic 1 - Backing added to hold putty filler. The 307 had only one vent on the leading edge.
Pics 2 & 3 - Adding styrene sheet former to extend the horizontal stabilizers.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, August 31, 2010 9:30 PM
Pic 1 - puttyed up horizontal stabilizer
Pic 2 - basic layout
Pic 3 - sanding off panel lines
    September 2005
Posted by richs26 on Wednesday, September 1, 2010 1:10 AM
What do you plan on using for the engine cowlings and the propellers since you are using the F as the basic structure to build off of.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    February 2010
Posted by hawkeye2an_L-Bird_fan on Wednesday, September 1, 2010 6:20 AM
In pic 1 at the bottom you can see the modified T-6 cowling that I am going to use as a vac mold to make the 4 cowlings. The props will be modified from the kit props.
    September 2009
Posted by B17Pilot on Wednesday, September 1, 2010 8:24 AM
This is great!  I wish someone would make an actual kit of the 307 in 48 scale.  Interested in selling a kit? I'd buy a couple. Wink
Great job, will be following this one with interest.  Which I had the skills to do this, as I've always wanted a 307.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Thursday, September 2, 2010 9:49 AM
I would be willing to sell a vac fuselage, it will be VERY ROUGH though. Wait 'til I get a pic posted and you can decide.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Thursday, September 2, 2010 9:53 AM
Pic 1 - upper wing sanded and primed.
Pic 2 & 3 - making the elevator actuator housings (4 needed)
    February 2010
Posted by hawkeye2an_L-Bird_fan on Saturday, September 4, 2010 7:14 AM
pic 1 - upper wing sanded and primed
pic 2 - tail buildup. Will need to be re-contoured slightly.
    September 2009
Posted by B17Pilot on Saturday, September 4, 2010 8:24 AM
Do you plan on putting in the cooling air outlet slots at the end of each wing?  Kinda curious how one would do that.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Saturday, September 4, 2010 12:06 PM
I believe you are referring to the anti-stall slots and they will definitely have to be added, they are very distinctive. Stay tuned I'll post pics.
    September 2009
Posted by B17Pilot on Saturday, September 4, 2010 12:54 PM
Anti-stall slots sounds better.  My Boeing cutaways book calls them cooling air exhaust slots, but that just didn't sound right especailly since they go all the way through the wing.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Saturday, September 4, 2010 1:55 PM
pic 1 - repositioning the rudder trim tab
pic 2 - insert for rudder extension added. The 307s rudder was much longer and with an extra hinge.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Monday, September 6, 2010 2:27 PM
pic 1 - piece of plan for general layout
pic 2 - cut out
pic 3 - piece of quarter round added for duct look, markied for brace positions
pics 4 & 5 - braces added
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, September 7, 2010 5:53 AM
Using the Monogram DC-3 cowling kit parts I pulled four shortened versions on the Mattel vacuform.
    October 2009
Posted by jetmodeler on Tuesday, September 7, 2010 6:37 AM
Looks like your coming along nicely.
    February 2010
Posted by hawkeye2an_L-Bird_fan on Tuesday, September 7, 2010 10:00 PM
Finishing up the slots. Still need a bit of putty and another sanding, but you get the idea
    September 2009
Posted by B17Pilot on Tuesday, September 7, 2010 10:11 PM
Wow This is getting better and better! Bow Down
    May 2009
Posted by Pawel on Wednesday, September 8, 2010 3:19 AM
Yeah, that's interesting - before you started the project I thought "new fuselage with everything else from the B-17". Now I see how many things need to be changed. And you do it just fine. So good luck - I look forward to see it done, and have a nice day
Pawel
www.vietnam.net.pl
    February 2010
Posted by hawkeye2an_L-Bird_fan on Wednesday, September 8, 2010 12:25 PM
Thanks for the comments guys. I'll be moving on to the fuselage next.
    May 2009
Posted by Pawel on Thursday, September 9, 2010 5:19 AM
Just can't wait to see that big shell formed! Have a nice day
Pawel
www.vietnam.net.pl
    February 2010
Posted by hawkeye2an_L-Bird_fan on Thursday, September 9, 2010 12:40 PM
Pic 1 - fuselage mold turned on a lathe by one of my fellow modellers.
Pic 2 - End forms from .060 styrene, to get the proper contour
Pic 3 - fuselage mold sanded and primed, ready for vacuforming.
Pic 4 & 5 - Getting an idea of what it will look like. If you haven't guessed this dude is going to be BIG !!!
    February 2010
Posted by hawkeye2an_L-Bird_fan on Friday, September 10, 2010 7:02 PM
rudder extensions added
engines and cowlings
    September 2009
Posted by B17Pilot on Thursday, October 13, 2011 8:55 AM
Hey Hawkeye, any progress on this? I finally track down a set of those plans! Only took a year! Still interested in a couple of those fuselodges.
Tags: C-75
    February 2010
Posted by hawkeye2an_L-Bird_fan on Thursday, October 13, 2011 9:11 AM
Your timing is amazing, due to getting a couple of commision jobs I have had to put this one on hold. I just pulled it out to get it started back up last week. I have formed a couple of sets of fuselages and have decided to go with a thicker plastic. Usually have to make a choice to mold thin enough to capture all the detail and curve of a subject. In this case there isn't any. So now I'm waiting for the thicker styrene sheets to arrive. I'll post some pics later in the week.
    May 2009
Posted by Pawel on Monday, October 17, 2011 9:34 AM
Hello!
I'm glad you're movin' on with this one! Did you notice it took you exactly on e year, to the day, to reply to my previous comment? Big Smile The fuselage is impressive. Now I wonder how you will do the windows! Good luck with this project, have a nice day
Paweł
www.vietnam.net.pl
    February 2010
Posted by hawkeye2an_L-Bird_fan on Monday, October 17, 2011 9:52 AM
Doesn't seem like it's been that long. Other projects and LIFE just got in the way.
On the workbench:
Lockheed SR-91 Aurora (What If) actually using a bit of the C-75 fuselage for this one !!
Boeing C-75
Howard UC-70
Curtiss A-1 Triad (first naval airplane)
I am doing WIP photos on all, but will not start posting until I'm sure I'll finish the model.
