Source for very fine plastic or PE mesh?
    January 2006
Posted by dirkpitt77 on Saturday, January 15, 2011 9:26 PM
    So, I'm working on AMT's classic TOS Enterprise, and I wanted to dress up the little "flux chillers" or whatever they are on the back end of engines.  I need some fine mesh or screen that is not woven (otherwise I'd just use screen door material or something).  Does anyone make a generic PE mesh like this, or grille material or something?  Thoughts?
        Thanks!
        Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    January 2005
Posted by Watchmann on Saturday, January 15, 2011 10:38 PM
Hi Chris,
Yes, K&S makes etch mesh sheets in square or diamond patterns.
m@
    January 2006
Posted by dirkpitt77 on Sunday, January 16, 2011 1:08 PM
       This K&S?
http://www.ksmetals.com/
    January 2005
Posted by Watchmann on Sunday, January 16, 2011 1:44 PM
That's it.  I don't like their webpage since it doesn't have good descriptions of their products, which I feel is kinda strange.
Here's a link that's a little more helpful.  I've never ordered from hobbylink before, and I'm not sure why they make you buy three sheets at a time.  I got some of the diamond mesh from my local shop.
m@
    September 2007
Posted by SuppressionFire on Sunday, January 16, 2011 1:58 PM
PE mesh is fine to a point, extremely fine mesh can be sourced from a sewing or fabric shop. Wedding veil works for many applications in scratch built model building. For the price of a few PE sheets you can have enough for a life time of model building, just mention what the use is for to avoid strange looks.Wink
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    January 2006
Posted by dirkpitt77 on Sunday, January 16, 2011 2:38 PM
Ahhh.....that helps.  Thanks, gentlemen!
    May 2003
Posted by qmiester on Friday, February 18, 2011 3:43 PM
Check out a fabric shop (or the sewing material area @ WallyWorld) for Bridal Vail material.  It can be found w/squares of 1/16" to1/4", in widths of 4 to 24 inches and in various lengths.  It's a not a plastic, rather some type cloth material (????) which is flexible and easy to cut.  I secure it with super glue.  I've seen it in various colors (white, black, blue, yellow and pink come to mind).  And it isn't that expensive.
Quincy
    September 2004
Posted by Borg R3-MC0 on Tuesday, March 8, 2011 2:05 AM
For very finer mesh I use plastic teabags, like lipton piramids.
    August 2006
Posted by HawkeyeHobbies on Tuesday, March 8, 2011 8:14 AM
Also check the plumbing department of your local hardware store...many fixtures require fine mesh screens which they sell replacement parts or bulk sheets.
Gerald "Hawkeye" Voigt
    November 2008
Posted by plasticjunkie on Friday, April 29, 2011 9:23 PM
The Dollar Store carries a fryer splatter cover thats close to a foot in diameter and is a fine wire mesh. Lots of material for a buck. The craft stores also carry extra fine metallic mesh ribbon spools.
 GIFMaker.org_jy_Ayj_O
    March 2005
Posted by mfsob on Monday, May 9, 2011 10:59 AM
Would some of these materials work in 1/72 aircraft, say for an oil intake?
    July 2004
Posted by stikpusher on Monday, May 9, 2011 5:00 PM
mfsob
Yes. I found that the fabric mesh used by Starbucks in their green tea bags is an excellent source of very fine mesh. Attach it with thin superglue, after it dries trim to fit precisely and BAM! So far I have used it 1/350 scale radar antenna screen and 1/35 scale helmet netting. Not to mention you also get a nice drink for around $2 out of it...Toast
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2005
Posted by mfsob on Tuesday, May 10, 2011 9:33 AM
*note to self - make Starbucks run on way home, ignore teasing from daughter later on*
So you glue the mesh into the opening and then trim it to fit, if I am understanding correctly? This is an oddly-shaped, quarter-inch or so hole.
    July 2004
Posted by stikpusher on Tuesday, May 10, 2011 3:14 PM
I would trim a piece to slighly oversize, glue it in place, then once the glue has dried, trim up any excess. Beter to adjust from too much than not enough.
       - Plankton
LSM
    March 2010
Posted by shoot&scoot on Saturday, May 21, 2011 8:51 PM
Bridal veil material makes good diagonal diamond pattern mesh and is available at local sewing supply stores.
        Pat.
    August 2005
Posted by Phil_H on Saturday, May 21, 2011 9:15 PM
You can also check stores which sell craft materials for ribbons with an appropriate weave. The one in the following example had a very regular, very square weave. About $2.00 for a roll about 4cm wide by about 4 metres in length.
    August 2008
Posted by tankerbuilder on Tuesday, June 7, 2011 6:39 PM
I know this is somewhat late , but , this can work for anyone ,anytime. There is a fine mesh that comes in three sizes (small, smaller, and very fine ) it is called "TULLE" pronounced "TOOL" and yes, it is used in the construction of bridal gowns and evening dresses for the ladies .To avoid embarrasment you can get this at MICHEALS and HOBBY LOBBY and yes , it comes in colors like light tan (MAUVE), black . and of course white ,red , green etc .  Check this stuff out . There is a lot to be found in mesh products at the model railroad dept . at HOBBYTOWN stores too .      tankerbuilder
    March 2005
Posted by mfsob on Monday, June 20, 2011 9:13 AM
And like an idiot - always check what you already have!
I found a "close enough is good enough" piece of mesh in my 1/700 ship photoetch, part of the safety netting that goes around aircraft carrier decks. Gold Medal Models is wonder stuff, as always. I think that'll work for the oil cooler intake on a 1/72 Nakajima Rufe just fine.
Posted by Don Stauffer on Tuesday, June 21, 2011 9:01 AM
Michaels (craft stores) sells an expanded aluminum mesh.  It is not super fine, but you didn't specify a dimension, so don't know if it would be fine enough or not.  Very reasonably priced.
    October 2008
Posted by bsyamato on Wednesday, July 13, 2011 4:19 AM
on prehistoric videogames with own led screen (don't confuse with modern lcd tecnology) i found on led elements a very fine meshed grid
for free
a single consolle have lots of them
    January 2006
Posted by SprueOne on Saturday, July 23, 2011 8:04 PM
good material source information in here Idea
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    August 2008
Posted by loachman on Saturday, August 13, 2011 10:49 AM
Many good sources of mesh material.  I'd like to add one that I have used--the fine mesh in filter screens for a clothes dryer.  Any good appliance store carries several with different mesh sizes and they are usually inexpensive. Just don't raid the wife's dryer unless you have a new screen on hand.
Posted by Woody on Sunday, September 4, 2011 11:17 AM
I have a very large stash of modeling mesh from Trimaster. It comes in hexs, squares, diamonds, etc and in many different sizes. It is the best stuff I've found for very small scale applications. I'm using a bit right now on my 1/1000 Light Cruiser.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    August 2008
Posted by tankerbuilder on Sunday, October 30, 2011 11:18 AM
I have to jump back in here with this reply to your post . Another good source is the permanent type COFFEE filters folks buy to make it neater? to make a pot o'  joe ! that screen is what you could call VERY FINE.   tankerbuilder
    June 2008
Posted by Hans von Hammer on Wednesday, November 2, 2011 9:45 AM
There's also a great source of it (although the quantities are pretty small) from the desecant capsules in some OTC medications The screen is what I'd call "Super Ultra Xtra-fine"
    July 2011
Posted by filters on Thursday, November 3, 2011 2:14 PM
How about some very fine metal mesh?  Will be more expensive but will also be a higher quality and last a lot longer:
http://www.bwire.com/
Something like a 100 x 100 mesh?
    April 2010
Posted by El Taino on Thursday, November 3, 2011 3:05 PM
Don't forget to pay a visit to your local Dollar store. They have strainers and sifters that might work. Also, the plumbing section of your local hardware store might also have strainers that can do the trick.
I use this kind of sifters, some times 2 or 3 different sizes for a buck.
    December 2011
Posted by Bilgerat on Friday, December 16, 2011 3:31 PM
Just to let every one know; K&S no longer makes P/E mesh. They stopped production late spring of this year. How ever; Loyalhanna Dockyard sells P/E mesh from England in many sizes and shapes.
    August 2008
Posted by tankerbuilder on Monday, January 23, 2012 7:13 PM
YOU have two ways to go here .Depending on the mesh shape you can use MODEL RAILROAD boxcar roofwalk material (it,s P.E. ) or you can go to your LHS that sells upgrade sets for the Models of GERMAN TANKS  , the upgrade mesh for the engine meshed hatch areas should work .       tankerbuilder
