Suggestions for a scratchbuild part on the Spirit of St. Louis
Okay, even though we have a hard-surface floor, and I work on a marble table, I seem t have a terrible time with parts vanishing in thin air on me. This is the second kit in a row that this has happened. It's very frustrating!
I have done a pretty decent job (I think) of reproducing the pitot tube off the wing, but I need to find a way to do the anemometer that sits on top of the fuselage. This is for the Revel 1/48 scale version of the Spirit of St. Louis.
I've tried taking brass and aluminum wire, flattening it at the ends and then going at one side of the flat with a center punch, but it really doesn't do much on the other side. Then, I'm concerned about how to get two such pieces joined in the middle and mounted on the mast. The aluminum wire, while softer, tends to crumble a lot, and again, the back side is flat. I've tried working on pine wood, and metal with the punch, but can't really get the back side to cup sufficiently.
Any suggestions will be considered. Thank you.
Regards,
Gene Beaird,
Pearland, Texas
