Any advice...
    February 2011
Any advice...
Posted by RotorHead10 on Friday, December 23, 2011 2:24 PM
trying to scratch some exhaust/intake plugs...
http://i301.photobucket.com/albums/nn48/MikeTheModeller/GB_Badges/Phantom2011_1.jpg
Posted by Don Stauffer on Saturday, December 24, 2011 9:56 AM
You might be able to make them from sheet styrene okay, but I would use the original model airplane scratchbuilding material, wood.  I'd try maybe 3/32 or 1/8  basswood.  That gives you some thickness for a contoured edge and some friction for a friction fit.
    May 2008
Posted by Boba Fett on Saturday, December 24, 2011 10:11 AM
Somebody I know has used foam. Cut it roughly to the size of the intake,shove it in. Then trim any excess that peels up on the intake insides with a sharp knife. You can't use the foam with BIG cells, like the white packing foam. Something with a very small cellular structure works best, a good example is Dollar Tree Foam-core-board. It takes away most of the work, just get the shape approximately right. And plus, no damage if you ever want to remove it. It's friction fit.
    July 2010
Posted by Echo139er on Saturday, December 24, 2011 10:29 AM
I read an article were this guy made his out of coffee cup lids (McDonald's).  The thin plastic is a good scale. I've been trying to find the article but no luck yet.
