Sprue;
I have the Bandai 1/24 King Tiger and Tamiya 1/25 Tiger I. I always wanted to build them with scale thickness armor, which means laminating from the inside.
Over the years I've accumulated styrene sheet stock, the best buy from a plastics wholesaler where I can get 4' by 8' sheets for around 40-50 bucks, I usually cut them down into 2' by 2' sheets.
Here are a few snaps of the progress on the King Tiger:
Naturally, I lied, this is on the outside underside, too crammed on the inside:
Note the plastic conformed to dips, detail, ejector, and shrink marks:
Front bottom glacis:
Side armour, black plastic is an industrial styrene strip, finished with laminated evergreen-style sheet:
Scratches are final burnishing:
Front glacis, same thick industrial styrene, finished with thin sheet to top up the scale thickness:
You can see the laminations a bit better:
The 'scale' I used was to follow the manufacturer's suggested weld marks, close enough:
Camera lens distortion, it doesn't look quite that warped in real life, side armor thickness matches the weld detail:
Back of the turret:
Right-side inside turret:
I have to rearrange the hardware inside the tank, Bandai didn't figure on a scale thickness glacis:
So that's the basic beast.
I used laquer thinners and a 3/4 inch paint brush to apply to the large areas. Well ventilated. MEK vaporizes too fast and creates bubbles. The toluene dries slower and I clamped, and those marks inside the turret are from a high pressure burnishing to insure there were no bubbles and provides full contact.
The technique was to apply a very thin amount of glue to both model and laminate sides, which only takes a few seconds to go into tack or dry, then a generous helping on the cut piece of laminate, then apply and clamp. I burnished after 15 minutes to ensure adhesion.
Yes, the plastic can actually soften a bit, so I let cure a full week or two before repeat operations. Its worth practicing on some waste material to test results.
I cut paper patterns, as was suggested above, for the turret and then bullied the styrene parts over the edge of a desk as well as persuaded it a hair dryer until it cooperated before I attempted gluing.
Tiger I's turret armor was a four inch thick plate wrapped red hot around a huge mandrel. Not a bad suggestion if you find the right diameter mandrel, then build it in three or so laminations.
