Styrene tube
    February 2013
Styrene tube
Posted by Raven Morpheus on Wednesday, August 21, 2013 11:00 AM
Silly question time -
Where can I get some 15mm (or preferably 13mm) inside diameter styrene tubing?
I live in the UK so that needs to be taken into consideration.
Thanks in advance for any assistance, google is failing me...
Posted by Rob Gronovius on Wednesday, August 21, 2013 12:18 PM
You want Evergreen plastic tubing. They have a contact email to see if they can tell you of a supplier close to your location. Many of the online hobby shops carry Evergreen so check your usual online shop in the UK.
www.evergreenscalemodels.com
Plastruct also has a line, you can check their website to see if a hobby shop carries it.
http://www.plastruct.com/
Basically look around for railroad modeling shops, they often carry this stuff too.
Posted by Bish on Wednesday, August 21, 2013 12:22 PM
These sell ever green in the UK. I have ordered other stuff from them before and they are good to deal with.
www.antenocitisworkshop.com/.../brands
Assuming the stores are still open, Model Zone usually has a range of Ever green stuff.
    February 2013
Posted by Raven Morpheus on Wednesday, August 21, 2013 2:38 PM
Thanks guys, I'll take a look.
Basically I'm trying to line a large hole I've made in the top of the rotor housing (to fit the rotor hub through) on the 1/72 HH-3E I'm building so it's recessed like on the 1/72 Fujimi/Revell Sea King models.
Think I'm wasting my time with tubing though, because I found an old mini-torch I've got that is 15mm diameter on the outside and I used that as a former for some 10thou strips of plasticard and wrapped them round to make the tube I want.  Also the largest Evergreen seem to do is 12.7mm (which if that's not the ID that's too small, and even if it is the ID it's still a little too small).
It didn't fit in the helicopter though because there are lumps and bumps in the way that I can't file/grind away because I'll probably end up going all the way through (they're where details have been moulded on the outside).
I think what I'll have to do is build up an interior so it's like a box, with a ceiling, then attach the rotor hub pin to the ceiling of the interior (raised up using a small box probably) and then just put a strip of 10thou plasticard around the inside of the hole I made in the top of the fuselage that the rotor assembly now goes through.
