I think it would be very hard to cast props in resin without a professional set-up. A pressure pot and a vacuum set up would be virtually required to keep the bubbles out of something as long and thin as a prop blade. I've only done open mold resin casting of small parts and have had a lot of trouble with bubbles.
That's why I scratch built the last time I needed props for the old Revell 1/115 scale P-3. I made a master template out of brass for one blade and used it to cut all 16 that I needed from card stock. I stuck the template to the card using double sided tape. I carved around the template and got 16 pretty uniform blades.
I shaped them all, one at a time by eye. Once you get the rythm of it, they end up pretty close. Probably not perfect, but I try to loosen up my perfectionist streak a little so as to not go crazy and so I can actually finish a model now and then.
The P-3 props have spinners that I made by modifying the kit spinner (longer and more steeply conical) and then cast in resin (with lots of bubbles) in an open mold.
The weapons are scratch built as well, not too much available in 1/115 scale in the marketplace!
