Try these steps on for size:
(1) After computing the scale size for the inside/outside diameters, go to a good building supply store. ( one of the big box stores, ex: Home Depot )
(2) Buy a length of molding called "half-round" of such size that when 2 pieces are held together, flat-face to flat-face, it'll give you the diameter you need for the INSIDE of you pipe. Get it long enough to give the length you need.
(3) Get a can of spray adhesive and some thin paper. Cut the molding into 2 working pieces and spray the flat faces with adhesive, then lay single layers of paper on one face and then bring the flat face of the second piece of molding together, face-to-face. You're making a "paper sandwich" . The result you're looking for is to have a round dowel with a layer of paper running through the round dowel's center.
(4) Step #3 has given you a dowel you can put into a lathe and turn scale corrigations into its surface; resulting in a mold for vacu-forming all of the "pipe" you'll need for your project.
(5) Once you've gotten the corrigations just right ( you'll want to make them extra pronounced so they'll translate good to the plastic sheeting ), separate the piece back into 2 half-round pieces. The paper you glued between the pieces created a weak line that will tear open when you are ready. That's a technique used in woodturning for turning mirror pieces for custom furniture decorations--among other things.
(6) Now that you have your mold pieces, don't forget to coat them with some good "release" substance, such as spray-on wax before bringing the hot plastic sheeting material into contact with them. Re-apply the release before each molding use. NOTE: You'll need to use thin sheets of plastic; such as .010 or thinner, to get the good inside and outside detail transfer from the mold.
(7) Glue the new plastic pipe halfs together and there's your scale corrigated pipe ready for finishing and detailing. Note: want an aged, bent end showing out from under the road bank? Heat that end with a good heat source ( heat gun, hot soldering iron, etc ) and press the pipe into shape with a wooden tool you've made from a piece of scrap.
(8) This method can be used for making barrels, trash cans, etc.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
