How can I fix a broken tailgun?
    July 2007
Posted by troublemaker66 on Monday, July 30, 2007 4:38 PM
Hi. I`m building a Monogram B-24D kit. While sanding, I accidentally pressed the tail turret into my gut and broke both barrels off of the twin 50`s. Can anyone give me some ideas on how and what to use to scratch build some new barrels? The kit is 1/48 scale and is out of production. Thanks,  Len
Len Pytlewski
    March 2005
Posted by mfsob on Tuesday, July 31, 2007 9:04 AM
I would think the proper diameter of styrene rod would do, in that small scale. You could try to "dimple" the rod with a pin vice and a No. 80 bit to give it more of a three-dimensional appearance, if you have that tool. Or just try stretching sprue to the appropriate diameter, and use super glue to attach so you get a good, quick bond. Just be careful to keep air circulating around the turret as the glue dries so the super glue doesn't fog the clear plastic.
    August 2004
Posted by Dubar1 on Sunday, August 26, 2007 10:57 AM
I recently repaired a couple of gun barrels on a B-17 model I built for my dad when he was still alive.  He was in the USAAF in the 9th air force.   After he died I brought it home with me and 6 of the guns were broken.
 I used very small diameter brass rod.  Drill the old bits of barrel out with a pin vise and inserted the brass rods.  Just as easy as any other method and not much chance of breaking them again!
