ship display cases
    April 2005
ship display cases
Posted by 110ryan on Tuesday, July 31, 2007 12:11 AM
Does anyone know of a good reference on how to build my own display cases for my 1/350 ship collection?  Mostly larger cases are needed for carriers and battleships.  I am only looking to do something to protect them from dust, so the most cost effective answer is probably what I am looking for.  Thanks, Ryan
    January 2005
Posted by mikepowers on Tuesday, July 31, 2007 3:51 PM
Unless your clever with tools and able to build stuff, I dont see a cheap way out of this.
Best bet would be to make a wooden shelf with particle board. Then hinge some cheap glass panels to it.
    March 2007
Posted by kcmat on Tuesday, July 31, 2007 11:47 PM
Ya I'd say you could either use lexan/plexi to make a cabinet out of shelves as mikepowers wrote. Or you could even use the plexi/lexan to make cases (like the ones we'v seen for car models and such) any size you like. Without forming it the corners won't look like the factory made ones but will certainly keep the dust off. A number of products work to adhere the pieces.
3rd option but would be pricey. There are plastics forming/machining shops around. Get a quote on some heat formed lexan cases. Or even if you make the sides like I mentioned above you could get a quote to have them plast-a-weld the seams. Anyway few options for ya.
http://www.myspace.com/madmat77
    June 2005
Posted by Powder Monkey on Wednesday, August 1, 2007 8:56 AM
    March 2005
Posted by mfsob on Saturday, August 4, 2007 6:58 AM
For me, it is cost effective to by individual cases for each ship. That way I can stack them if necessary and move them around from time to time. I know that some in here don't like the IMEX brand of cases, but they fill the bill for me - cheap, fairly well made and stackable (I have a very small apartment!)
    September 2006
Posted by the Baron on Tuesday, August 7, 2007 11:41 AM
Hi, 110ryan,
 If you're set on building your own, I recommend making a drawing first, it's what I do when I build a piece of furniture.  As far as glass goes, I'm still not proficient at cutting it cleanly, so I order panes to measure from my local glass supply company (eg, a place that makes replacement panes, as part of its business of installing and repairing home and business windows).
 However, I saw a really neat tip a couple of years ago, in an online build of the Trumpeter 1/350 USS Hornet:  Use a baseball bat display case.  You should be able to get them through your nearest sports collectible dealer; if he doesn't have any on hand, he can probably order it.  Or search the 'Net for one.  But the prefab bat display cases are perfect for ships in 1/350 or 1/700.
 Happy modeling!
Wot
    January 2006
Posted by Wot on Wednesday, September 12, 2007 5:23 PM
Hello,
   I've built a few cases for ship models in the past and used 1/8" plexiglas sheet. It's best to draw out a plan first, dimensioning each side of the case, then simply draw the pieces directly onto the peel-away paper that covers the 'glas. I used a band saw or table saw to cut it (cuts a lot like wood but tends to melt if the blade gets it too hot) being careful to get as close and accurate as possible. When the pieces are cut out, sand the edges as flat as possible because the plexiglas glue is applied with a syringe or similar device and gets sucked into the joint by capillary action. Very strong joint when it's cured which takes only minutes. After the box is assembled, I used wood corner trim to hide all of the joints, then mounted the model on a nice wooden base and secured the case to base. The plexiglas is lighter and stronger than glass and the only drawback with the stuff is that is scratches fairly easily.
   Hope that helps!
I stop in the local cafe now and then just to see what I've been up to.
Posted by kp80 on Thursday, September 13, 2007 5:59 AM
Where can I find plexiglas and plexiglas glue?  Are they available in places like home Depot and Lowe's?  Is there a certain brand that is preferred?  I've heard of a GE product called "Lexan"; is this plexiglas or something else?
Wot
    January 2006
Posted by Wot on Thursday, September 13, 2007 12:00 PM
   I believe Plexiglas is a trade name, as is Lexan; they are similar but Lexan is stronger, perhaps more scratch resistant, and more expensive. It's the product often used as "bullet proof glass". I buy mine at the local hardware store but it's also available at businesses that sell glass. They also carry (or can get) the glue. Have never tried to buy it at Lowe's or Home Depot.
Wot
Posted by SNOOPY on Sunday, September 16, 2007 10:50 AM
I believe it was a FSM issue, May 2001 (I think) that had an article on making your own display cases.  It gave pretty detailed directions.  The issue had a Bicentennial decaled F-106 with the letters saying City of Jacksonville.  The gentleman uses plywood for a base, acrylic/plexiglass for the body, and spruces it up with moulding around the edges.
    September 2004
Posted by flaver on Wednesday, November 7, 2007 5:44 AM
You could try going to a custom glass store. I'm in Toronto and in the construction industry, I was at a glass supplier of mine, those stores that will replace panes of glass, cut glass shelves etc...
I asked him about a display case for a 1:350 battleship I have. He said he could make one using tempered glass, using a no seam glue with polished edges. So it would be completely glass no wood frame holding the panes together. It would cost around $200 CND for the glass and For the base I need to make it my self which is not a huge deal if you are ok with working in wood, just take a plank of some nice wood router out the edges or nail some 1/4 round trim to te edges, fill sand and stain and thats it, whole thing should cost about $225 with about 1 - 2 hours making the base.
    March 2005
Posted by mfsob on Wednesday, November 7, 2007 12:17 PM
*does the currency conversion into US dollars* Ouch. Any way you do it, getting something nice to put your model in is going to be expensive. Sigh ...
    August 2005
Posted by EdGrune on Wednesday, November 7, 2007 1:02 PM
I had a custom case made at the local trophy shop for a commission build I did.   Walnut base, Lexan box for about 60 USD (of course the cost was passed on to the customer).
    February 2005
Posted by prowannab on Friday, December 7, 2007 3:50 PM
 the cheapest method would be to go to hobby lobby and buy some cheap plexiglass.I think the cost is around 11-12 bucks and you get a pretty good size sheet,now it's not strong enough to hold anything,but you can cut it to the length and width.then glue the pieces together just to make a dust sheild.oh by the way for 1/350 you might need to buy 2 peices for that scale.
Patriae Fidus (FAITHFUL TO MY COUNTRY)
