Siege Machine
    March 2004
Siege Machine
Posted by DanCooper on Monday, January 14, 2008 1:31 PM
A couple of days back my son asked me if I could build him a crossbow, after checking the internet I found it would be far too dangerous (if I actually could make it work).
However, knowing how much he loves playing rts games, I offered him a compromise, I offered him to build a working 1/25 scale model of a midieval Trebuchet. He accepted and the search for knowledge started again (thank Google). When I started my research, I had no idea that trebuchet-building is a hobby (or sport) on its own and most of the drawings I found were for modern-day equivalents of trebuchets that had near to nothing in common with the historical ones.  Till I found a downloadable free paper model... it looked perfect for what I had in mind.
So, all that needed to be done now was getting wood... off to the local hobby shop, and dad came back with 6 beams of 10x10 wood (all dimension I use are metrical !)
The fun could begin...
The first two pieces glued together
The base of the machine almost ready (about 1.5 hour later)
Starting to resamble the midieval equivalent of a B52 bomber
And the business-end of the machine
And at that very moment I realized something was buggering me about the whole thing, and than I realized that I was making it too clean, using machined beams, while the real thing was make with the aid of axes instead of cnc cutters. So, I had to do something about this.
Today after I came home from work I started the process of making the wook look like it was handcrafted strait from the trees, using nothing else than my trusted nr11 blade. The next 2 pictures are to be considered as "before" and "after"
And applied to the whole machine it gives this as a result
While typing this report, the next pieces are already drying, so it won't take long before the next progress will be posted here.
On the bench : Revell's 1/125 RV Calypso
    March 2005
Posted by grizz30_06 on Tuesday, January 15, 2008 11:05 AM
Now that is cool.
I guess you saw the site about some folks here in the States who build modern Trebuchets and try to hit a junked truck with it?  After you get done with this one do one of those that would be very funny.
Grizz
PS Any chance you would share the web site where you found the plans?
Denial, it's not just a coping mechanism, it's a way of life.
    April 2005
Posted by wing_nut on Tuesday, January 15, 2008 11:48 AM
Very cool project.  Next time the punkin chunkin championships are on the tube... check out the monster Trebuchets they build.
Marc
    October 2005
Posted by Kolschey on Wednesday, January 16, 2008 7:16 AM
Looking great so far! I'm definitely staying tuned to see how this beast turns out.  Thumbs Up [tup]
Krzysztof Mathews http://www.firstgearterritories.com
    March 2004
Posted by DanCooper on Friday, February 8, 2008 12:23 PM
Sure, why not Smile [:)]
http://members.home.nl/papermodels
Oh, btw, the "functioning" or "working" part of the model, well, the counterweight just heavy enough, so it will become a static model, however it will be posed in a dynamic position when finished, of course with figures in a diorama.
Concerning the figures, which is something I have zero to nul experience in, so I have a question... 1/25, what "scale" of figurines would that be ???
Hmm, last time I checked the TV-guide, I wasn't able to receive US channels over here in Belgium Big Smile [:D]
    March 2005
Posted by grizz30_06 on Friday, February 8, 2008 12:35 PM
Well 1/25 would be 1/25th.  I know that 1/32nd is 54mm (many times people mix 1/35 and 1/32 they are so close).  I am not sure what 70mm and 90mm would be but I think they might be in the ball park (or "close").  You might even get away with 54mm but the treb would look like a really really big one.  Does any of that help at all?  I think that Tamyia does a 1/20 (or maybe 1/24 scale Formula one pit crew,  but I imagin there might be some conversion needed).
Grizz
    September 2015
Posted by Aaronw on Monday, March 3, 2008 5:42 PM
I built one of these a few years ago, about 12" (30cm) tall. I wasn't going for total authenticity so I just used fishing weights for the counter weight. Getting the sling right was the hardest part, I had to keep adjusting the length of the string and the angle of the hook to get the right release point otherwise it would shoot straight up or go into the ground. Once I got it adjusted it worked pretty good. The sling was the perfect size for a piece of dog food, it would fling it a good 8-10 feet. My son was about 3 and he had a great time using it to feed the dog one piece at a time from across the room. Big Smile [:D]
    January 2005
Posted by mikepowers on Monday, April 28, 2008 9:37 AM
Hi Dan, and guys.
What ever happened to this build? I would like to see the results.
Very interesting change of pace.
    January 2003
Posted by leemitcheltree on Wednesday, April 30, 2008 5:55 AM
Dan,
How has the Trebuchet build progressed?  It looks great so far.
I'm sure we'd all love to see the next installment.
Cheers, LeeTree
Remember, Safety Fast!!!
    August 2007
Posted by Townsy11 on Tuesday, June 17, 2008 3:48 PM
Sign - Ditto [#ditto]
"The object of war is not to die for your country, but to make the other bastard die for his."-- General George S. Patton
    December 2006
Posted by Hieronymus on Wednesday, November 19, 2008 7:29 AM
that trebuchet brings back some memories. I do  not know anymore perhaps it was a movie but somehow I got interested in this and I started looking around for some pictures and plans for such a machine. Finally I staretd to built one of my own. Did not work very good so I changed a couple of things until I was able to throw a little rock a few meters. Sure that was not good enough and so I started to build the next one. This time I builded it about 4 ft. high and used some barbells for counterweight. During my first test I was able to fling a tennisball about 250 meters!!! Unfortunately I tried to improve this performance even more and the machine was damaged beyond repair. But until that time we had a lot of fun!!
keep on modeling
René
www.usns.biz
keep on modeling: www.usns.biz
