Does anybody know where I can get a set of decals for a Qantas A380 in 1/144?
Edit: Above was the original post, just going to reuse the thread for the build, see below
Yup here you go http://www.airline-hobby.com/shop/index.cfm?action=ViewDetails&ItemID=14581
Cool. Thanks!
Anytime.
FInally got time to sit down and buy it. Thanks again 9x19mm! I couldn't help myself and besides the A380 and Qantas decals, I picked up one of the Zvezda 787s
Make sure and post pics during the build!
Stay tuned has I build this beast! Should start her up in the next week or so. Got to finish up a couple of GBs, which are in the painting stage, but might start this before, you never know.
The build begins!!! I put sheet plastic behind the windows for support for the upcoming putty that will fill in the windows, since the Qantas decals come with windows. Man there is a lot of windows! Put two of the four main wheel struts together, along with the nose wheel strut. These along with the inner combustion chamber for the engines aer waiting for a coat of alunnmim. The decal sheet also provides windows for the cockpit, so I assembled the cockpit tub provided and am going to leave it unpainted, since I just going to use it for structure support.
Here's a couple of pics.
That is about as far as I got a few months ago, then got busy trying to do some flying. It's a cool kit, great work so far and keep us posted.=
-Jonas
Made a little progress. Got the engine cores painted, and the fuselodge and wings have been glued together, just not to one another almost to that point though
Made a little and I do mean little, progress on the big airliner! Got the engines all together, minus the end exhaust cone. Windows have been puttied over, but I need to go back and fix some. I dry fitted the wings, and engines to the fuselodge to find any fit problems later. So without farther delay the dry fit: (Brings to mind a question, where on earth am I going to put her when done? She's bigger than my 1/48 B-17!)
Wings have been attached and got her all ready to be painted. Still debating if'n I should put a gray primer on her first before the white goes on. Need to check seams and cover the landing gear and exhaust cones on the engines. Any way here she is all ready to be painted.
Windows all filled in:
The engines are in need of some paint
Nice build.
Thanks Halfpint33!
Progress update: got the first coat of white on her, definitely needs more than one.
After three coats of white, the tail was painted red. Though during the process of getting the tail painted, I broke off the lower half of the nose gear and the carpet monster ate it. After debating which I felt more angry about (breaking it off or losing it), I found another A380 kit on sale and its being shipped to me. A quick copy of the nose gear and good has new.
Then I started masking to paint the wings and what do you know I got to repaint the red on the bottom What's that old saying, two steps forward, one step back? well I think at the moment its two back, one forward. Hopefully no more issues will arrise and things will go smoothly
The top looks good though, see for your self (note the nose down incline due to the broken nose gear)
Looking a really nice build, I built the very same kit but in Virgin Atlantic livery (dunno why) a couple of years ago. Look forward to the finished kit.
Scott.
I'll hit the brakes, he'll fly right by.
She's all painted. Now to go fix that broken nose gear.
She's looking sweet, think I can almost hear the engines spooling up.
7474 - Thanks! The engines are actually on the side. Going to work on those after the airframe is done.
Got the nose gear fixed. Since I did break it off and luckly broke it off at the pivot point, I went ahead and turned the nose gear to the right. Deffintely will look different when done. Now here's to hoping I don't break this nose gear off.
OK so just ran into a dilemma. While working on the landing gear, I noticed that the kit supplied main gear doors for the ones attached to the fuselodge, are not right. According to pictures over at airliners.net, the doors are suppose leave a hole for the strut and be flush with the fuselodge, not to the side of the gear exposing the gear bay. Still undecided on whether I should modify the gear doors to make it look right or go with the kits instructions.
Well after looking at many pictures, I saw that it was an easy fix to make it look like the real one, so away I went. Here it is all done and looking like the real thing
Lookin good so far.
sorrry but how did you paint it? Airbrush or spraycans?
Jumpingmanjim sorrry but how did you paint it? Airbrush or spraycans?
I airbrushed it. First the white, then the red and then the wings (light grey first, then the dark one).
Status update: went to attach the outter main gears and found out they where too long (don't know if I didn't get the wings on right or they just molded them wrong, I'm thinking the latter cause when I did attach the gear they sat on all for wheels, but where long, so I don't know). Will need to cut them down to size, but only like an eighth of an inch, maybe less.
Update Time! The decals and all small bits have been added. A quick semi-gloss coat to seal it all in a little weathering and the main part is all done. Next up the engines.
Here she is:
I finally got the engines finished. Would've had her done two days ago, but much needed rain showed up.
You forgot the blown out engine lol
Looks awesome man. Well done.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming
Check out my blog here.
Scorpiomikey You forgot the blown out engine lol
That's on the other side.
Thanks!!
Great looking scarebus. Nice job!
Very nice build, but now you need to damage one engine to make it fit the latest news. :P
