This is a Minicraft kit that I have started on.
Most of the interior is completed, now it is onto the body of the craft where I have been adding epoxy putty and cleaning up panel lines.
I still have to cut new glass for it and working on fitting a windsheild that I have cut from a piece of clear packaging to obtain the compount curves that it has.
I've been using Modeller's of Japan bare metal foil and a few Detail Master PE products.
The landing lights were cut in with a file to the leading edge of the wings, a glass jewel glued in and then filled with epoxy. This was the first attempt at such a thing, and discovered everything went clear and the only thing visible was the reflector on back of the jewel. Interesting result. I've also made clear epoxy wing tip light housings.
The display base has a brass tube installed for a rod to the plane and is filled with blue clay and then sealed with epoxy and sanded flat. The exterior was sprayed with texture paint. The badge details were covered with chrome foil, painted and then clear epoxy poured over it and left to cure. Polished up nice. All this has been experimentation on my part and so far not too bad.
