Revell 1/48th Spirit of St. Louis
    January 2010
Posted by CrashTestDummy on Thursday, July 14, 2011 5:50 PM
I finally got the pictures uploaded to my fotki account, so here it is.  It's taken me a while to finish this.  I thought I'd assemble this kit as a 'quick build' but it quickly got out of hand.  Not liking the cowling decals, I decided it would be cool to do some engine-turned foil and add it to the model.  That was a tedious job, but turned out pretty cool, IMHO.  Next time, if there is a next time, I think I'll opt for some regular foil, and not the chrome stuff.
[View:/themes/fsm/utility/:550:0]
I also added some wiring to the engine, and weathered the exhausts a bit, but that doesn't show up very well.  I also added some oil streaks to the bottom of the cowling to mimic oil staining on the real bird, but that, too, didn't come through well.
The floor monster got a LOT of parts.  Although there aren't that many parts with this kit, I did end up loosing some.  The parts I lost included the anemometer, the little tube on the starboard wing strut (speed indicator?) and pitot tube.
I fabbed all these parts.  The anemometer was created using a piece of brass tubing for the center piece.  I drilled 4 holes and then epoxied four pieces of brass wire to the tubing.  Once that was set, I created some 'cups' out of aluminum foil punched out with a small hole punch and cupped them with a burnishing tool.  They were then epoxied to the wire ends.  The whole thing was then painted with alclad (I figured the arms an cups would be stainless, or polished aluminum).  The center piece then got a coat of aluminum paint I used for the rest of the plane.
To improve the details some, I added the control wires for all the flight surfaces, which can be seen in some of the photos.  I also added some details in the cockpit, including changing the manual fuel pump levers to wire, adding some wire to the throttle controls, and additional details to the instrument panel.  I don't have a very good picture of the cockpit, though.  Sorry.
Anyway, here's the rest of the bird for your review.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
Posted by Don Stauffer on Friday, July 15, 2011 8:45 AM
Very nice!  Your cowl and spinner came out really great.
That kit is very nice.  I have built the model and was pleased by the kit. I did use the decals for the engine turning, and did have some trouble but was able to piece together enough from the alternate decal sheet to fill the gaps.
    May 2011
Posted by AceHawkDriver on Friday, July 15, 2011 11:11 AM
Very cool!
I've seen this one quite a bit at various hobby shops and always thought about picking it up and now I just might have to.  Really like how the foil turned out!
Peace through superior firepower.
Brian
    January 2010
Posted by CrashTestDummy on Friday, July 15, 2011 1:58 PM
Thanks, all.  And it is a nice kit.  Not a lot of parts, comes with a seated or standing Charles Lindberg (one head, so you have to choose your body of choice), which I didn't do.  The kit goes together well.  Easy, fun work, unless you loose parts, like I did.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    February 2007
Posted by Buckeye on Monday, July 18, 2011 11:29 AM
Very nice build!  What did you use to get the finish on the cowling and spinner?  It came out great.Toast
Posted by BaBill212 on Monday, July 18, 2011 11:50 AM
Great job Gene,,,,   Very nice indeed.             You did the kit justice for sure!
Mostly               thanks for sharing
Bill
Enjoy the ride!
    January 2010
Posted by CrashTestDummy on Tuesday, July 19, 2011 2:34 PM
Buckeye
I took a regular #2 pencil, and cut the eraser diameter down so it would fit in a small circle template.  I traced the outline of the existing decals to determine how much foil I would need, then marked off that area on the foil, leaving some extra space for muck-ups.  I set the circle template down on the foil, pushed the eraser head through the template, onto the foil and gave it a couple of quick spins.  I then moved the template forward a bit, allowing for some overlap of the eraser over the mark previously-made, pressed the eraser through the the template and gave it a little spin.  Wash, rinse, repeat.  I used a straight edge to run the template down to keep things kind of straight.  When I reached the end of my work area, I moved the template over a bit to start another row, again, allowing for some overlap, and then realigned the straight edge against the side of the template so I could slide it down the straight edge as I worked.  I think I used like a 3/16" circle for the work.  Too big, and it looked odd, too small, and you really couldn't see much.  It's a little out of scale, compared to the real engine turning, but still allows one to see the effect okay.
Yes it took a while.  I worked until my thumb and fingers hurt, rested a bit then started again.  I believe I got the inspiration and technique, perhaps with some modification based on what I had available, from this forum.  The above technique is basically what I did, though.
I then took my tracings of the decals mentioned above, and use that to cut out the individual pieces.  I laid the pieces down as you would normally lay down foil.  I laid down the bottom part first, then the top part, and then the sides, as that looked like the way the cowl panels are arranged on the real Spirit.
I then put the decals on, with some setting solution.  After that,  I dipped the cowling and spinner in Future and let that set.  I then added little dots of aluminum silver enamel via the tip of a toothpick, to emulate Dzus fasteners along the edges of the panels, as on the real plane.  They look okay under magnification, but not very visible in the photos.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    February 2007
Posted by Buckeye on Monday, July 25, 2011 11:27 AM
Very creative and again, excellent job.Toast
    September 2005
Posted by Sprue-ce Goose on Saturday, September 3, 2011 9:32 AM
Very nice build !
I find your explanation about the engine turned aluminum very interesting.
Thanks for the post.
Now I want the kit.
BTW...I have a floor tile monster.
Lost an off white piece of plastic on a white vinyl tile floor.
I'll be on the floor with a flashlight looking for that one for a while..Embarrassed
