Missing Hasegawa B-17F 'Nose Art' 1/72 cockpit/bombardier compartment parts
    August 2011
Posted by 8thAAF_Builder on Monday, August 15, 2011 4:01 AM
Hello all,  I found my old B-17F 'Nose Art' from Hasegawa in 1/72 stashed in the attic. However im missing all the cockpit/bombardier room parts, if anyone happens to have these parts (say unusable because of aftermarket cockpit parts purchase) I'd be very happy to have them for a fair compensation. I think Academy B-17 cockpit parts should be ok too with little work.
Also I wonder if the Legend 1/72 B-17F Detailing/Interior set provides all the door and floor parts as well which im missing at the moment, since purchasing that set would be a solution as well?Actually this set is for the Academy kit but I guess it should fir the Hasegawa one as well. Can anyone familiar with this aftermarket set confirm this?
Best regards, I.K.
Posted by Bish on Monday, August 15, 2011 4:11 AM
Not sure about the legend set, but there is also a CMK resin set, but again this is for the Academy kit. But you shouldn't have a problem fitting these to Hasegawa. Which doors do you mean. I am currently building the Academy 17F and useing alot of Eduard PE and these include all 3 external doors. Unfortunatly the only left over kit parts are the pilot and co pilot seats.
    August 2011
Posted by 8thAAF_Builder on Monday, August 15, 2011 4:25 AM
Thx for the quick reply bish. I meant the bombardier room and cockpit floor parts and the door to cockpit as in this photo: http://imageshack.us/photo/my-images/844/b17fj.jpg/ , these serve ofcourse as the basis for the cockpit & bombardier room compartment, ofcourse one can build them from scratch but I would try a more easier way :) I just wondered if those parts are included in the Legend set or are they from the basic kit..
Posted by Bish on Monday, August 15, 2011 4:46 AM
Right, with you now. My guess would be that if this is a resin set, it would have everything. Generally, with the resin pits i have used, they replace the lot. This image of the CMK set shows which parts should be included, and i would guess the legend set is the same.
http://www.hannants.co.uk/product/CMK7076
Is that iamage you showed the legend set, as that looks very nice, and the bomb bay looks alot better thatn the Eduard one i have been doing.
Posted by Bish on Monday, August 15, 2011 4:52 AM
Ok, just found their site, and i can see that that image is the set you mean. If thats everything thats in the set, which it should be, then i would say no, the parts you need are not included, as thats a PE set and not resin. My advice would be to go for a resin set, unless you can find someone that has used a resin set and has the spare parts. PE sets won't give you what you need.
    August 2011
Posted by 8thAAF_Builder on Monday, August 15, 2011 4:56 AM
Thank you Bish for your trouble. I guess I should go with the CMK set or just try and find someone who has the leftover parts (a longshot).
Posted by Bish on Monday, August 15, 2011 6:19 AM
No problem. To be honest, i wish i had gone for the CMK set as it looks alot better than the PE. But i went for the Eduard Big Ed set.
